Aftermarket headunit on platinum series gs300
Does anyone else have the problem where your radio shuts off when u turn it up past 20? Im running an alpine cda 9833.
iModerate
Are you using the factory amp or did you bypass it?
Any error messages on the head unit itself when this happens?
Does the volume come right back on as soon as you turn it back down to 19?
yah, I believe the problem is that the stock wiring is not providing enough juice to the deck to run it at high volumes with the internal amp on... and a new power wire either from the battery or another thicker power wire you may find behind the dash. If you have time running a power/ground directly off the batt will produce the best results.
Personally I got lazy and turned up the gains on my aftermarket amp and I just don't go up to where the deck goes into low voltage protection....
With the 9833 if you are not using the internal amp you can turn it off in the setting iirc which should help as well..
jjjjjjj
12-12-02 08:18 PM
