1998 GS400 transponder key program
Old 07-12-11, 01:03 AM
hkvan
hkvan's Avatar
Default 1998 GS400 transponder key program
Anyone have info on programming a new transponder key? I have one original but would like to have a duplicate. I have searched the forums and found the sc programming sequence but not the gs. Thanks.
Old 07-12-11, 11:55 AM
dejavu157
dejavu157's Avatar
i thinkd ud have to take it to a dealer.
Old 07-12-11, 12:04 PM
sakataj
sakataj's Avatar
u do not.....
give me a second to find it, im a little busy so it may take me a minute but they on here, i used them to program my second master key
ALSO OP not sure where or what you searched but i searched with keywords "program master key" and got 5 pages of threads....the "program key" and got 10 pages of threads,so im calling shenanigans on you actually searching.
https://www.clublexus.com/forums/gs-...need-help.html
Old 07-12-11, 12:47 PM
hkvan
hkvan's Avatar
I swear to God I'm going to pistol whip the next guy who says, " Shenanigans." Thanks for the info sakataj but I am tring to program it to start the car.
Ok, here is what I found:
To duplicate a key:
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.(DO NOT TURN)
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time. At this time the security light starts blinking.
7. After 45 to 60 seconds new key is registered and security light goes off (stops blinking).
8. Remove new key and try starting the car.
Old 07-12-11, 02:40 PM
sakataj
sakataj's Avatar
oops wrong directions then but they were in the 15 pages you could have found had you actually searched? also specify which directions you need next time
Old 07-12-11, 02:51 PM
lexybaby77
lexybaby77's Avatar
To duplicate a key:
Nice info
Old 07-14-11, 03:47 PM
lexybaby77
lexybaby77's Avatar
To duplicate a key:
Did you try this and it worked? I lost my valet key and bought one today. Did not have them program it so I can give this a try.
Old 07-14-11, 04:25 PM
hkvan
hkvan's Avatar
Ok, it took a couple times but it works.
Old 07-14-11, 04:33 PM
hkvan
hkvan's Avatar
Make sure when you depress and release the brake or accelerator its a smooth fast motion.
Old 07-14-11, 04:36 PM
lexybaby77
lexybaby77's Avatar
Thanks for the tip!!! Will do this tonight. Did you depress the brake and accelerator pedals all the way?
Old 07-14-11, 08:47 PM
hkvan
hkvan's Avatar
Yes, you need to press the pedals all the way down.
Old 07-14-11, 09:46 PM
lexybaby77
lexybaby77's Avatar
Thanks man. It finally worked after 3 attempts.
Old 07-14-11, 10:02 PM
Big Mack
Big Mack's Avatar
Talking
Shenanigans. Consider the gauntlet dropped, but remember - I hit back.
Big Mack
Old 07-14-11, 10:04 PM
Mr Jokster
Mr Jokster's Avatar
wow, thats MUCH less than the others I've seen to do I suppose if it works, it works... Guess theres more than one way to do it.
Old 07-15-11, 01:24 AM
hkvan
hkvan's Avatar
Just out of curiosity, what are the other way you speak of? I now know the way above works for a 98 gs400 but if there are other ways that might help others, then let's get it out.
Quick Reply: 1998 GS400 transponder key program
