gs300 won't start after replacing battery
Old 04-15-11, 08:58 PM
Ice1213
Ice1213's Avatar
Default gs300 won't start after replacing battery
My battery died over night. my neighbor said he heard the alarm but it had stopped. when I tried to use the remote to unlock doors I realized the battery was completely dead. I tried jump starting the car but the engine would never crank, (the engine cranked fine prior to this night)the power door locks, windows and other accessories work fine. I replaced battery and still nothing. I've read that leaving your key in the on position for a few minutes might work, but it didn't. Lexus just says to bring the car in. Is this an immobilizer or alarm issue that i can just reset? Can someone please help , I haven't been able to use my car to get to work.
Old 04-15-11, 09:03 PM
aprince1
aprince1's Avatar
Does the engine crank?
Old 04-15-11, 09:06 PM
Ice1213
Ice1213's Avatar
no the engine doesn't even crank. the dash lights dim when i put the key in start position as it normally would during a start up.
Old 04-15-11, 09:08 PM
aprince1
aprince1's Avatar
With the key in the accessories position everything inside the car turns on?
Old 04-15-11, 09:11 PM
Ice1213
Ice1213's Avatar
yes, radio, adjustable steering wheel, inside lights. the alarm light flashes once i remove the key but extinguishes once i insert it.
Old 04-15-11, 09:20 PM
aprince1
aprince1's Avatar
You will have to try testing the starter. That may have croaked.
Old 04-15-11, 09:23 PM
Ice1213
Ice1213's Avatar
is there an immobilizer for this car? If not then I will try to test in the morning.Thanks for your time.
Old 04-16-11, 06:06 AM
YviE
YviE's Avatar
Had to jumpstart the car the other day, because I had left the trunk open during several days. Car started fine. The car didn't run fine in the beginning as it seemed if the throttlebody was "learning" all over again (ECU reset).
Old 04-16-11, 06:28 AM
Ice1213
Ice1213's Avatar
thanks. I will test the starter in an hr or so..i will keep u guys updated.
Old 04-16-11, 07:42 AM
Ice1213
Ice1213's Avatar
the starter is not getting any voltage to it. I hear the starter relay clicking to on. is there a reason for this..did any one ever had this happen before?
Old 04-16-11, 10:38 AM
Ice1213
Ice1213's Avatar
the starter is getting a + voltage to it. but no ground..fuses are all good.
Old 04-16-11, 02:11 PM
kamikaze04
kamikaze04's Avatar
check your fuses also
Old 04-16-11, 02:29 PM
99 GS3
99 GS3's Avatar
Not sure what you mean by no ground? The starter housing is the ground and is bolted to the block.. There is no actual ground wire going to the starter.
Old 08-10-18, 05:01 AM
helitaz
helitaz's Avatar
How do I reset the engine immobilizer or the security shutdown on my 2006 Lexus GS300
Old 08-10-18, 06:36 AM
captainva
captainva's Avatar
This is the 2GS section. Try posting in the 3rd gen forum.
Quick Reply: gs300 won't start after replacing battery
