Why ABS activates when doing a broken u-turn?
Old 04-24-12, 08:09 PM
GS4_Fiend
GS4_Fiend's Avatar
Definitely a broken wire on one of the front wheel ABS speed sensor.
Old 04-30-12, 07:44 AM
justablkv8
justablkv8's Avatar
Yeah, but can it be that intermittent?
Old 11-05-13, 05:15 PM
lamchop1
lamchop1's Avatar
Check the rear abs tone rings. My abs was coming on on hard right turns below 5mph. I found inside the knuckle there is a wheel bearing dust shield. The rust behind it was pushing the dust shield into the abs ring. The abs ring was ground almost flush. Unfortunately the ring cannot be bought separately, you have to replace the whole axle. The dust shield has to be removed and clean the rust behind the shield, then replace with a new one. Did mine last week. Good as new.
Attached Thumbnails Why ABS activates when doing a broken u-turn?-20131101_141356.jpg
Old 11-06-13, 10:09 AM
PHML
Master Thread Closer!!
PHML's Avatar
do you have ABS fluid topped off?
did anyone work on the suspension or brakes prior to the ABS coming on?
if so, sometimes ppl mount the ABS line either too high or too low onto the aftermarket suspension. When turning max left or max right, the ABS line is stretched…and causes the ABS lights to turn ON. Prolonged stretching of the line may have cause permanent damage and thus, you may be experiencing issues when driving straight. Check the ABS line by jacking up your car…remove the wheel, and turn max left and max right. Inspect the ABS line.
Old 01-13-15, 03:45 PM
sivikvtec
sivikvtec's Avatar
Replacing the axle and dust cover 4245130010 fixed my problem.
Tank
Suspension and Brakes
29
09-03-21 02:31 PM
QPedro
ES - 5th Gen (2007-2012)
07-25-17 08:10 AM
gsCrazy
03-20-17 09:26 PM
tipp
01-14-11 01:29 PM
rstep1
06-10-07 08:17 PM
Quick Reply: Why ABS activates when doing a broken u-turn?
