HELP! car alarm goes off when battery is connected
By doing something like this, you are asking that connection to instantly put every system that runs when the car is operating on, and could cause very nasty sparks when trying to connect it. If you are trying to blow fuses, this is a good way to do it. Remember to connect the negative terminal last, too.
I'd also recommend not doing it at night if you don't want your neighbors getting irritated.
Big Mack
so after some extensive rocket scientistry I've discovered the answer! I just had to unlock the car with the key while the alarm was going off...wouldn't u know it..
hi there, i have got the same problem on my is 200 . so can you describe whole proces please , was it like all doors locked - connect a battery- unlock drivers door with key ? or ? How did you do it ?
alotakoon
12-07-08 06:32 PM
