Wheel width/offset/size and tire fitment Q&A thread
Old 04-19-15, 08:25 PM
  #781
vlpz760
vlpz760's Avatar
Originally Posted by Riksgs808
Sup victor.... Glad to see you still on the teins and your making progress on your build. Im on 19x9.5 with 225/35 and 19x10.5 with 245/35. Has a little stretch on it. Your offsets will determine if you need just rolling, shaving, pulling on fenders and quarters.
sup man yeah looks like thats the sizes imma be running, shot me some pics of ur set up when u got sometime.
Old 04-21-15, 09:48 PM
  #782
2kaygs300
2kaygs300's Avatar
ive read and reread most of this, and im sure ive missed something, so ill just ask. looking to get some es2's soon. supraa front brakes , so ill need a +22 in front on a 19x9.5 in order to clear the tt calipers.. question is can I do a 19x10.5, or even 19x11 out back with like +35? thinking possibly a 255 or 265/40 rear tire. lowered on eibach sportlines and bilstein sport shocks . any help is greatly appreciated. I'd lke to do without modding my fenders.
thanks guys.
Old 04-21-15, 10:46 PM
  #783
NorthStyle
NorthStyle's Avatar
I'm running a 20x11 et30 w/ a 275/30 on coilovers and it fits just fine with a shave.... However, the 40-series tires you're looking at are too tall for a 19, you'd be better off looking at 35 or 30 series depending on how wide you wish to go.
Old 04-24-15, 05:58 PM
  #784
Turch
Turch's Avatar
Default fitment
How difficult would it be to fit some weds that are 19x10 -4 and 19x11.5 -3
Old 05-06-15, 06:48 AM
  #785
daj430
daj430's Avatar
Will be running a 20×9.5 front 20×10.5 rear with ls400 front calipers and figs camber kit what offset should I run for flush look also on coilovers and tire size??
Old 05-12-15, 08:45 PM
  #786
tusker464
tusker464's Avatar
Hi. I have an 06 gs300 awd. 17" factory rims/ tires.Completely stock. The only upgrade is vented drilled/ slotted brake rotors. I am sure this may seem redundant and maybe ridiculous but I have a killer deal sitting in front of me. 4 stock chrome 19" rims off of a 2010 ford Taurus. The bolt pattern is the same but it looks as though the center hub/hole is larger by just a bit on the Taurus rims. The rims have stock Goodyear tires. 350 $ for all 4 rims and tires mounted. But it does no good if they will ruin my car. Will these just bolt on or will they be the "money pit" rims...Any input is greatly appreciated. Thanks.
Old 05-13-15, 04:08 AM
  #787
Tido17
Tido17's Avatar
Hi Lexus lovers and gurus
I'm planning to get some 19inch ssr sp3 rims.
What width and offset would fit nicely on a IS250 2007 model.
I want the wheels to be tucked and no fender mods
Tyre sizes as well.
Thanks
Old 05-13-15, 04:59 AM
  #788
Lutkis
Lutkis's Avatar
Tyre sizes as well.
Thanks
It could be very hard to get answers to that on a 2nd Gen GS subforum.
Who knows, maybe you get lucky.
Old 05-13-15, 09:38 AM
  #789
Riksgs808
Riksgs808's Avatar
Turch- your setup would be considered aggressive or even extremely aggressive to some. You will need to roll the crap out or the fronts you need almost an inch and a half up front and rears will need to take to a shop for custom quarter pa el work. I wouldn't suggest doing it yourself unless your body work skills are on point.
Old 05-13-15, 09:49 AM
  #790
Riksgs808
Riksgs808's Avatar
daj430- hard to answer your question. Depends how much negative camber you are planning to run. (eg. If you plan to run about a -5 or -6 ) +20 in the front and +17 in the rear should bring you just about flush. This was my original setup I just explained to you.
Old 05-13-15, 09:51 AM
  #791
Riksgs808
Riksgs808's Avatar
Lutkis......... I was thinking the exact same thing for the last two posts. Lol. I almost thought I gave wrong info on the wrong thread. Lmao
Old 05-15-15, 02:28 PM
  #792
re-rx7
re-rx7's Avatar
how sunk in will 18x8 +35 look?
Old 06-01-15, 01:06 AM
  #793
Zoolander
Zoolander's Avatar
Get some 20 or 25mm spacers and it won't be bad at all.
Old 06-01-15, 01:08 AM
  #794
Zoolander
Zoolander's Avatar
I'm having a set of rims made and want 19*9 and 19*11. My fronts are rolled and the rear is shaved. I'd like to not do any further work if possible.
For offset, should I do +15 and +20? What tire size would be best? The goal would be to tuck a bit.
Would a 19x10 +13 work with just rolled front fenders or would I need a pull?
Thanks!
Old 06-14-15, 06:22 AM
  #795
madfish
madfish's Avatar
Hi, I've had a good skim through this thread and can't see a similar set up so seeking advice in what work to do...
Front and rear
Rota grid drift 18x9.5 et30
245/35/18 (very mild stretch)
20mm and 30mm spacers available
Rear arches have been partially shaved
Very low on HSD coilovers...
Thanks guys
Quick Reply: Wheel width/offset/size and tire fitment Q&A thread
