GS300 Braking issue need help
Old 10-14-10, 11:02 PM
zenki s14
zenki s14's Avatar
Default GS300 Braking issue need help
I am new here and i have purchased a gs300 and i need you guys opinion about the braking issue i have. well when i brake the car it seems to pull to the right more and the braking is not distributed evenly. what could be numerous things that i need to check for or if you guys have had the same problem as i am. i would like to know what to look for before i start replacing the front brakes and rotors. thanks.
Old 10-14-10, 11:56 PM
JeffTsai
JeffTsai's Avatar
Probably just a stuck slide pin in one of the calipers.
Old 10-15-10, 12:42 AM
alexdan
alexdan's Avatar
could be something wrong with the brakes (service and inspect the front brakes) also could be an alignment issue or bad suspension parts..really hard to tell without an inspection.
Old 10-15-10, 07:55 AM
zenki s14
zenki s14's Avatar
thanks guys for the help if anyone has more opinions feel free to drop some info the help is much needed.
Old 10-15-10, 08:00 AM
YviE
YviE's Avatar
Stuck slider pin or seized pistons.
Take the front calipers off, clean them, check the pistons, clean & regrease the sliders pins.
Old 10-15-10, 09:56 AM
FrankT
FrankT's Avatar
x3 check'em
Old 10-15-10, 10:53 PM
zenki s14
zenki s14's Avatar
thanks guys for the help much appreciated i will most definitely check them tomorrow or sunday.
Old 10-15-10, 11:27 PM
HAWAI'I
HAWAI'I's Avatar
nO! check them now, it's your brakes homeboy!
Old 10-16-10, 12:20 AM
PHML
Master Thread Closer!!
PHML's Avatar
probably a seized up piston.
Old 10-27-10, 10:14 AM
zenki s14
zenki s14's Avatar
well it seems that the noise shims are loose where it clips to the back of the brake pad. everything else looks fine as i inspected the calipers and rotors.
Old 10-30-10, 10:25 PM
zenki s14
zenki s14's Avatar
well i re-greased the guiding pins and replaced the brake pads and test drove the car and it seems to fix the problem for right now i guess we have to see for another few hundred miles or so. also looked at the caster arm might have to replace the bushings on that as well.
Old 10-31-10, 09:52 AM
krispl
krispl's Avatar
Could be that they weren't bled properly.
turbosix
18
02-11-20 01:01 PM
otis_jzs
Suspension and Brakes
02-21-10 09:47 AM
Xeeeeeem
20
01-10-06 09:20 AM
SUPRA OWNER
03-19-03 06:37 AM
Quick Reply: GS300 Braking issue need help
