Timing Belt parts
Old 10-12-10, 08:13 PM
CrystalGS3
CrystalGS3's Avatar
Default Timing Belt parts
Hi everyone,
I just ordered some parts today through Sewell Lexus to change the timing belt on my 03 GS300 with 68,000 miles. I was wondering if someone can give me some opinion of whether I'm good with my list or I should do more. Thanks for any input.
Parts list:
1. timing belt kit (timing belt, water pump, idler, 3 O-rings)
2. timing belt tensioner
3. thermostat
4. thermostat O-ring
5. water pump gasket
6. water pump O-ring
7. water pump rear pipe gasket
8. serpentine belt
I'm also considering the pulley cam gears, if that is necessary. I want to get the HKS cam gear set. Is that a good upgrade?
Old 10-12-10, 08:35 PM
renatodato
renatodato's Avatar
Don't forget the coolant and radiator hoses.
Old 10-12-10, 11:21 PM
bighead222
bighead222's Avatar
Default reply
how much was all that im about to do the same thing wanna know if thats all correct and if theres any thing eles missing..
Old 10-13-10, 10:55 AM
maximus54
maximus54's Avatar
Definitely do the cam and crank seals. I would only do the HKS cam gear is your plan on modding your engine as the benefit of the HKS cam is tuning capabilities. Otherwise it looks good.
Old 10-13-10, 07:30 PM
krispl
krispl's Avatar
Don't even mess with the seals UNLESS they leak. What do you need radiator hoses for? I didn't change mine and they are still in a great shape. Once again if you have extra money you want to drop into parts go ahead but it's not required. Dealership doesn't even change houses or seals unless they leak or are broken. That's just my 2c.
Old 10-13-10, 07:49 PM
CrystalGS3
CrystalGS3's Avatar
bighead222: All of those items cost me $405 shipped.
I'm not sure what are those 3 o-rings included in the timing belt kit. Are those the cam and crank seals? Is there any good in getting the HKS pulleys vs. stock ones if I don't mod my engine or is it money wasted?
Old 10-14-10, 08:57 AM
Chin
Former Sponsor
Chin's Avatar
I believe the o rings are for the water pump (inlet, bypass...)
Old 10-14-10, 06:09 PM
bighead222
bighead222's Avatar
Post reply
thanks i got to do it nice lil chunk of change but rather be safe then sorry thanks.
Vadim540i
SC- 1st Gen (1992-2000)
18
06-18-14 07:31 PM
ivnnln
12-23-12 09:53 AM
Vito 06430
08-20-12 09:59 AM
qwerty04
03-10-12 09:18 PM
memGS300
09-02-09 06:54 PM
Quick Reply: Timing Belt parts
