2GS led side mirror install help
I found some diy's for the 3GS but none for the 2GS. Anyone know what wires to tap into for the driver and passenger turn signals when installing led side mirrors? Which wires for the puddle lamps?
TIA!
TIA!
Former Sponsor
Seee
I would the the following, but if someone else can confirm please step in.
1) Turn Signals, you can tap the wire harness that runs next to the drivers side under the door still. You will need a wiring diagram so you know what wires are left and right.
2) Puddle lights, here you have two options.
A) Tap the courtesy lights on the door panel.
B) Tap the dome light on the fuse panel under the dash by the kick panel.
Hope this helps you out, again if someone else has a better way please step in.
Seee
pm sent....
Thanks for the response guys.
My main question now is where can I get a hold of a wiring diagram? or do any of you know exactly which color wire it is for the turn signals? I don't have a test light anymore.
looking at the wiring diagram, the green/black goes behind the left kick panel and the green/yellow goes behind the right passenger kick panel.
theoretically since the wire runs around the car, you should see it in the wiring loom running by the door sills on both sides but i wont know for sure till i get mine in this weekend.
btw dont thank me for the PDF'S abel sent them to me.....thank him
iModerate
i should have mine done this weekend guys but yes, i attached the wiring schematics INCLUDING the door ecu and power mirrors for the puddle lights...
