Quick question about tire size for VIP look
Old 07-13-10, 09:13 AM
Automan
Automan's Avatar
Default Quick question about tire size for VIP look
Guys I need a quick answer to this question please. My new wheels arrive tomorrow and I need to secure some tires. What tire size do I need to go with to fit these wheel specs. Now I don't want an unsafe or over stretched tire just a nice stretch and ideal for fitment.
Wheel specs:
Front 20x9 -1
Rear 20x11 +12
Thanks
Old 07-13-10, 11:20 AM
geeznuts
geeznuts's Avatar
225/35/20 in front and 245/35/20 or 255/35/20 rear im running 255/30/20 on 20X10.5 & it looks great but did you look on VSC on tire stretch
Old 07-13-10, 11:25 AM
BrentGS
BrentGS's Avatar
255 or 265 on the 11
225 or 235 on the 9
Old 07-13-10, 12:02 PM
Sonic_RC
Sonic_RC's Avatar
Here is the the setup I'm running on my 20x9 and 20x10.5
Front: 225/35ZR20
Rear: 255/30ZR20
With this setup you will have same tire height front and rear and equal stretch with out too much stretch.
I would not go for geeznuts setup unless you want a taller rear tire. Not to mention the rear tire size is oversized
Old 07-13-10, 12:27 PM
speedaddic
speedaddic's Avatar
how bout you guys post up some pics of your setups with the 225/35 and 255/30? I'm curious about 20" on a GS as well... I was going to go 225/30 255/30 but I'd like to see the 35 series
Old 07-13-10, 12:30 PM
lunatyk
lunatyk's Avatar
Sorry to thread jack but anyone ever run a higher profile in the rear? For example, 225/35 front and 245/40 rear? Does it have any affect on the ride?
Old 07-13-10, 12:32 PM
vwynn
vwynn's Avatar
itll affect how fast u are actually going vs the MPH reading.
Old 07-13-10, 12:54 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
this is the setup i had works well
Old 07-13-10, 03:12 PM
Sonic_RC
Sonic_RC's Avatar
You can go with a 225/30 but the size wall is SUPER small and the load capacity is much lower making it easier to blow the sidewall. the factory 16" is 205/60R16 which is 26.16" overall diameter and a 225/35R20 is 26.2 overall diameter so its the same.
Just because the side profile is 35 front and rear does not mean the sidewall height is the same. Take for example 225/45R17 and 255/40R17 have the exact sidewall thinkness where as 255/45R17 would be 1" taller in height and would look way off.
If you are going to buy new tires make sure the tire overall diameter is between 25.3-26.3. If you are not sure what is the overall diameter is, here is a link to the company I work for
http://www.1010tires.com/TireSizeCalculator.asp
Here is my setup with 225/35ZR20 front and 255/30ZR20 rear Falken FK-452
That would be rediculous First of all 245/40R20 is closer to a crossover/SUV size and is almost 28" in height. It would rub all over the place and not to mention look stupid.
Old 07-13-10, 04:15 PM
Vincent123
Vincent123's Avatar
225/35/20 and 245/35/20. Id rather have a slightly bigger sidewall to prevent bends and have a little bit more comfortable ride, rather than driving on rubber bands
Old 07-13-10, 05:19 PM
chrispy
chrispy's Avatar
If it's strictly a show car I would do 225/30/20 and 245 or 255/30/20. Sounds like you need all the help you can get to fit those offsets.
Old 07-13-10, 07:01 PM
lexus310
lexus310's Avatar
^^ yea thats what i have!! i had 30s before and the ride was very rough!! felt the road to much!!
Old 07-13-10, 07:42 PM
Automan
Automan's Avatar
Ok time for some education here. If I had to guess or go at this alone I would have chosen these tire specs. Why is this NOT good for the fitment I need.
Front 245/35/20
Rear 275/35/20
Old 07-13-10, 09:21 PM
5t341th
5t341th's Avatar
I am going to have the same specs as you as well. i am going for 215/35/19 on a 9" and 235/35/19 on a 11"
thru some research, that gives me the look i want plus the clearance i will definitely need
Old 07-13-10, 09:38 PM
excluesive
excluesive's Avatar
find out the clearance you need for you fenders first... PERIOD
Quick Reply: Quick question about tire size for VIP look
