Wknd mission complete but....
Old 07-02-10, 05:14 PM
J$mooth23
J$mooth23's Avatar
Default Wknd mission complete but....
Ok so last wknd I got around to installing my Megan coils and Linea Corse Dynas wrapped in Hankook V12!
But after re-taking it in for my coils to be adjusted I realized that my vsc+abs+vsc/off lights are all on. I did the search and found multiple threads on this issue but it seems as though the problem could be anything. I mean there's a pretty big general list of possible issues but I need a bit more specific info and decided to post this since it hapnd right after adjusting my coils.
So with that being said could anyone advise me on something? I tried disconnecting my battery for a while but it's still there. Here's some pix for now. I'll post more when I get to around to modding it some more! Thanks for your input.
Attached Thumbnails Wknd mission complete but....-3.jpg   Wknd mission complete but....-4.jpg   Wknd mission complete but....-2.jpg   Wknd mission complete but....-1.jpg   Wknd mission complete but....-getattachment.aspx.jpg
Old 07-02-10, 05:28 PM
MrExecutiv
MrExecutiv's Avatar
clean GS
Old 07-02-10, 05:41 PM
5t341th
5t341th's Avatar
they coulda broken a wire or something.
Old 07-02-10, 05:42 PM
lexo98
lexo98's Avatar
you might have pulled on the abs sensor wire. Hook it up to a code reader
Old 07-02-10, 07:01 PM
wbmx1981
wbmx1981's Avatar
Nice ride! I like the look!
Old 07-02-10, 07:11 PM
fenderzig
fenderzig's Avatar
Those megans look like they go pretty low! Are they fully dropped up front or do you have some more room to go?
Old 07-02-10, 07:14 PM
Caoboy
Caoboy's Avatar
Check your abs sensors, they may have left one unplugged, or they broke one of them. Don't look at anything else. It is one of the ABS sensors for sure, I'll put money on it.
Old 07-02-10, 08:41 PM
istundra
istundra's Avatar
a while ago, when my ES300 was in the shop, the mechanic hyper extended the ABS sensor wire by letting the whole brake caliper dangle by the wire!!!!
I had to buy a use one and replace it.
Old 07-02-10, 09:05 PM
Caoboy
Caoboy's Avatar
You can solder the wire back together and it'll work fine, there is a write up from JeffTsai.
Old 07-02-10, 10:36 PM
RAWKUSsd
RAWKUSsd's Avatar
car looks really dope. I like the clear n red 99 taillights.
Old 07-03-10, 01:23 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Turned out great.. clean GS
Old 07-03-10, 03:14 AM
geeznuts
geeznuts's Avatar
Nice ride.. Hope your mechanic didnt break the abs sensor
Old 07-03-10, 04:49 AM
Mr Jokster
Mr Jokster's Avatar
not if it isnt the wire... could be the actual sensor. I found a break in my wires, fixed them and abs light still on
Old 07-03-10, 09:24 AM
V8RdnLow
V8RdnLow's Avatar
looks clean
Old 07-03-10, 10:20 AM
Jherb350
Jherb350's Avatar
^^...Check what he said first. You have also bumped the sensor and it is could not be in the right place. I had the same thing happen to mine after I did my springs and bushings, lights came on, car drove fine so I had the coded pulled and it was the sensor on the passenger side that wasn't in the correct position.
Quick Reply: Wknd mission complete but....
