why would you such a thing?
Old 06-26-14, 09:14 PM
pinoiryder
pinoiryder's Avatar
Default why would you such a thing?
so i received error code for O2 Sensor.. I ordered the sensor and now trying to replace it.. In the process of removing the old sensor.. had a really hard time removing it and guess why?
Previous technician who replace the O2 Sensor welded:thumbed: the new one..
Attached Thumbnails why would you such a thing?-20140626_210842_w-215th-st.jpg
Old 06-26-14, 09:21 PM
monkey92
monkey92's Avatar
wow that really sucks, how did you end up getting it out?
Old 06-26-14, 09:30 PM
pinoiryder
pinoiryder's Avatar
I have to force it out.. took me more than an hour to remove it.. good thing is the grommet ( i think thats what its called) on the manifold is not damage..
Old 06-26-14, 10:22 PM
offbad
offbad's Avatar
jesus wtf, the inhumanity...
Old 06-26-14, 11:39 PM
Lutkis
Lutkis's Avatar
What indicates it was welded? I've changed two O2 sensors and they've both looked like that (the threads) after the removal.
Old 06-27-14, 01:30 AM
clos430
clos430's Avatar
Lol! That's the way they come out sometimes. It was not welded on. When it's a pain to get loose spray some wd40 and keep going back and forth meaning loosen sensor to it gets stuck and retighten.
Old 06-27-14, 05:29 AM
burny
burny's Avatar
^this is it
Old 06-27-14, 11:42 PM
pinoiryder
pinoiryder's Avatar
I check the other sensor and they all came out easy.. I don't think even if they have not been replace before it should not that hard to loosen it.. I soaked it overnight with some penetrating lubricant and still have a hard time to take it out..
Old 06-29-14, 10:45 PM
Lutkis
Lutkis's Avatar
They can be a PIA sometimes.
Heating with a blow torch is one way to try to get them out in good condition.
Old 06-30-14, 07:07 AM
TRDmkII
TRDmkII's Avatar
definitely not welded. Stupid heated oxygen sensors do that sometimes.....They can be a PIA.
Old 06-30-14, 08:19 PM
Lexusjg1
Lexusjg1's Avatar
Yeah I've had mine come out looking like that too. Make sure you use an anti-seize agent before you put on the new one. Never seize etc....
Old 07-02-14, 10:32 AM
czr73
czr73's Avatar
How often - or - at what mileage should I changed my O2 sensors out ??
I'd like to avoid the experience you had with it.
Thanks..
Old 07-08-14, 10:10 PM
pinoiryder
pinoiryder's Avatar
Only change the O2 Sensor because it was throwing codes.. as the saying goes.. "if its not broken don't fix it"
Thanks..
Lexmex
RX - 1st Gen (1999-2003)
179
12-18-19 08:02 PM
ISFLexy
Performance
12-06-17 07:00 PM
Iparkcars
02-24-17 06:27 AM
Eric00GS3
03-22-11 12:55 PM
Blaizze
10-03-08 12:37 AM
Quick Reply: why would you such a thing?
