Insurance taillights issue help!
Old 04-08-10, 09:25 PM
duby1
duby1's Avatar
Default Insurance taillights issue help!
Hello,
I recently got a set and it and when i installed it. I think it blew my brakes fuse. I put back my OEMs and its still the same.
My light would turn on, but when i press my brakes... It won't go off. Could it be the resistors that comes with it and is over loading my modular.
My lights have three plugs; one to the main tail-lamp socket and the other two to the resistors. So, does the LEDs have too much power for the main socket?
Anyone else with Insurance taillights having this problem?
Old 04-08-10, 09:30 PM
duby1
duby1's Avatar
Which fuse do i need to exchange to get my brake lights working again?
Old 04-08-10, 09:45 PM
GS4_Fiend
GS4_Fiend's Avatar
Sounds like you got a short on the power side. I wouldn't recommend using a higher fuse because you might burn the wiring. You would need to track where that short is coming from. GL
Old 04-09-10, 05:31 AM
Tuanville
Tuanville's Avatar
When you press on the brakes, it won't go off? That's because you're pressing on it?
I don't think you should use a higher fuse, you'll burn your wiring up that way for sure. There's this little button behind your brake peddle, see if it comes back out when you let go of the brakes. Check all your taillight fuse.
Old 04-09-10, 10:52 AM
duby1
duby1's Avatar
imma check that out.
Old 04-09-10, 11:23 AM
Sonic_RC
Sonic_RC's Avatar
I have a similar issue. When I push the brakes the indicator light would come on and would go off once I release it. It works fine but I hope I dont short out anything. But its very rare that the indicator light come on so I ignored it.
Old 04-09-10, 01:18 PM
gytsi
gytsi's Avatar
No short and no indicator light when push the brakes. but, indicator light would come on and stay on once i turn the headlights on.
Old 04-09-10, 01:20 PM
duby1
duby1's Avatar
My brake light won't flash when i press the brakes... So, i don't know. I'm going to check into it this weekend...
Old 04-09-10, 01:32 PM
PHML
Master Thread Closer!!
PHML's Avatar
try switching around the 2 main brake light bulbs around....(not the reverse or turn signal bulbs).
Old 06-30-10, 11:33 PM
Chris4.3
Chris4.3's Avatar
I just got mine and it worked fine for a few days. My fuse blew, so I replaced it and worked fine. Then the parking lights would not come on, but when I stepped on the brakes, it worked. I couldnt drive it at night cuz parking lights wouldnt come on. It also messed up my the sensor? (small black box inside left trunk handle) Maybe we need to swap the resistors?
Old 07-01-10, 02:08 AM
Damnnchi
Damnnchi's Avatar
Dang! I was thinking about getting these tail lights too!...not anymore thats for sure...but sorry I couldnt be of any help good luck!
Old 07-01-10, 03:25 AM
Mr Jokster
Mr Jokster's Avatar
Dont let a couple complaints stop you from buying them. its a quality light, better than the ebay crap thats out there! I've had mine for 2 years and have had NO problems with them.
Old 07-01-10, 06:36 AM
excluesive
excluesive's Avatar
you can "mod" the resistor box
Old 07-01-10, 10:36 PM
duby1
duby1's Avatar
Chris4.3 - i think i might have seen your car pulling out near my work every morning. Off el camino. I work at the office buildings right behind baby r us.
i've seen a black GS with insurance taillights. i always wonder who could that be.
Anyways,
what i did was... just took off the resistors box... And it worked perfect since. no problems.
After that, i rigged the some wiring so i won't be able to see the taillight out.
And yes! these taillights are amazing. the quality of it is top notch. not cheap at all.
Old 07-01-10, 10:55 PM
Damnnchi
Damnnchi's Avatar
I just dont want to have to deal with any dash light what so ever...the way I see it is...if they dont work just as the stocks do then, I'll be happy with my stock tail lights. But we shall see.
Quick Reply: Insurance taillights issue help!
