Front Passenger Door not locking
Old 03-04-10, 11:59 AM
xamtseeb84
xamtseeb84's Avatar
Default Front Passenger Door not locking
I don't know how to fix cars so I depend of forums. =D I have a 2000 Lexus GS300 and all the other doors lock except for the front passenger door. You have to manually click the switch on the door in order for it to lock. I think because of that, the door won't unlock with the button on the key, instead, it requires inserting the key and then unlocking by turning the key.
Help anyone?
Old 03-04-10, 12:01 PM
Sash1mi
Sash1mi's Avatar
You need a new actuator, period.
Dara
Old 03-04-10, 12:09 PM
xamtseeb84
xamtseeb84's Avatar
how much are they usually, how do I install it and where can I get one?
Old 03-04-10, 12:12 PM
Sash1mi
Sash1mi's Avatar
PM sewell-lexus he should get you a price there as for installing.... I didnt do mines I had my dad do it for me.
Dara
Old 03-04-10, 12:18 PM
xamtseeb84
xamtseeb84's Avatar
tried looking him up on the member list but couldn't.
Old 03-04-10, 12:23 PM
TheBean
TheBean's Avatar
I borrowed this from another member.
Old 03-05-10, 02:33 PM
xamtseeb84
xamtseeb84's Avatar
I took the car to my co-worker's shop and he said he can hear a clicking that it could just be a clip that's not working or something. The actuator costs $400 for a brand new one. GOOD GRIEF! Help?
Old 03-06-10, 02:14 PM
Vlad_Stein
Vlad_Stein's Avatar
From what you are describing, you have a bad actuator(s). If the lock works mechanically (by using a key or interior lock switch, but not by pushing a button on a key fob), then it is the actuator.
The bad news is that Lexus does not sell just the actuator, or the actuator assembly. The sell the whole lock assembly, which is 90% what you don't need.
The good news is that if you are a bit mechanically inclined and are willing to put in a day's work, you can fix all for very cheap.
See this thread for details:
https://www.clublexus.com/forums/gs-...ators-diy.html
I purchased 4 motors from Ebay for $38 shipped (they are more expensive now than before, from what I read, but this is not too bad, compared to $280 for the lock assembly). Look for the
http://cgi.ebay.com/ebaymotors/ws/eB...OU%3AUS%3A1123
What you are looking for is Item:4-pk Lexus/Toy Door Actuator repl Mabuchi FC280PC-22125.
Make sure you order the motor without the brass coupling on the metal rod - you will have to take off the existing coupling from the bad motor(s). You might as well get some grease that is used for plastic parts (I didn't).
I replaced a bad motor in the front passenger door. After you read the thread for instructions on how to take off the door panel and lock assembly, look for my post in the end of the thread on testing the lock assembly (both mechanically and with a key fob) before you put it back in - it may save you some time and headache. Overall, a very doable job if you use your head and don't have $1000 to have it done by the dealer.
Old 06-11-14, 05:05 AM
johnhol123
johnhol123's Avatar
Default Door Locks Problem Too
I'm having same problem with 1999 GS300. Was hoping someone would answer your post so i could find out too. Maybe someone will be kind enough to tell us our problem. John
Old 06-11-14, 07:03 PM
ttaylor993
ttaylor993's Avatar
Here is the link from the previous post.
https://www.clublexus.com/forums/gs-s...ators-diy.html
There is a ton on information on this forum on this issue since it is very common; almost inevitable over time.
This an easy DIY if you are just a little mechanically inclined. You can get actuators from eBay for about $100. You can get the motors that go in the actuator for about $20 for 4. The motor is what goes bad, not the whole actuator. If you replace the actuator it'll take about 30 minutes, If you replace the motor in the actuator, add another 20 minutes. Good luck.
Old 06-12-14, 05:52 PM
GS300OC
GS300OC's Avatar
I just removed my front passenger door lock as it was bad. Here were my steps for the DIY motor swap.
Step 1: Open the case. It cracked in multiple pieces. No big deal, I can epoxy back together.
Step 2: Finally got to the motor inside, great. I could easily see that the brushes were burnt.
Step 3: Remove the OEM gear mounted on the shaft. Small drill bit, small taps from a small 6oz hammer.
Step 4: The OEM gear shatters.
Step 5: I threw it all in the trash and ordered a new OEM door lock for $200.
Step 6: Cry and post my sorrows on here.
Old 06-12-14, 06:39 PM
DosyBoy
DosyBoy's Avatar
Geeze man that sucks but why would u tap on it with a bit and a hammer, it comes right out without a lot of force.. Oh well stuff happens
Old 06-12-14, 07:04 PM
ttaylor993
ttaylor993's Avatar
Sorry to hear that. A $10 gear puller from a hobby shop would have taken that fitting off. Or, you could have gotten an actuator from eBay for under a $100. Oh well, stuff happens!
Old 06-26-14, 03:26 PM
GS300OC
GS300OC's Avatar
In case anyone has a use for that old lock assembly that I have.
Free - pickup in Santa Ana CA.
-front bumper turn signal lights aka "clear corners". Good condition. Removed and put OEM amber ones in.
-front passenger door lock assembly. motor housing/case cracked apart when disassembling, but the cables and such are perfect.
booner714
RX - 1st Gen (1999-2003)
04-08-17 08:50 AM
alabamaman
01-31-12 02:12 PM
SloGS400
01-15-11 10:11 PM
deviategs
GS - 1st Gen (1993-1997)
09-22-10 03:29 AM
Gregor99
02-02-10 12:58 PM
Quick Reply: Front Passenger Door not locking
