Need an Answer ASAP
Old 02-26-10, 02:02 PM
kingbigs11
kingbigs11's Avatar
Default Need an Answer ASAP
I am getting ready to order these wheels. they are 19x9.5 all the way around. I am putting them on my 02 gs3. Will i have issues with the 9.5? As far as rubbing and what not. I know i can't fit the 20x10 up front. Will the 19x9.5 be good?
Old 02-26-10, 02:25 PM
RI-Lex
RI-Lex's Avatar
It depends on the offset really, wish I can help you more.
Old 02-26-10, 02:28 PM
porn-adkt
porn-adkt's Avatar
Why would you order anything if your not well informed whether it will fit or not
Old 02-26-10, 03:28 PM
kingbigs11
kingbigs11's Avatar
point of this thread is to get informed before i order them Just trying to find out if anyone knows " first hand" if they will rub or not
Old 02-26-10, 03:29 PM
j stuff
j stuff's Avatar
what we need to know is the OFFSET and the width. FIND THAT MUCH OUT! Then we can let u know
Old 02-26-10, 03:31 PM
kingbigs11
kingbigs11's Avatar
rims are 19x9.5 all the way around. With 35 offset
Old 02-26-10, 06:11 PM
MaSfLOw
MaSfLOw's Avatar
..i thought u ordered your wheels the other day ?20s ?
Old 02-26-10, 07:24 PM
kingbigs11
kingbigs11's Avatar
i was about to buy the 20's but i wanted the 20x10 all around. Because i dont like the small lip on the 8.5s. So the 19's have the big lip all around
Old 02-26-10, 08:33 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
I would advice doing some searches on widths and offsets.. I'm not that knowledgable in this area but 20x10 in the front will not work unless you roll the fenders and are going for VIP... 20x10 in the rear is fine.. you want 20x8.5 or 9 for the front..
Old 02-26-10, 08:48 PM
porn-adkt
porn-adkt's Avatar
heres what u need.
Offset Calculator (online)
current wheel spec (on ur car)
Ruler/straight edge (office Depot)
12th grade Math level comprehension
good luck
Old 02-27-10, 10:38 AM
kingbigs11
kingbigs11's Avatar
Originally Posted by ****-adkt
heres what u need.
good luck
Isnt the point of posting threads and asking questions is to find out " the easy way". By picking people brains and seeing what they already know?
Old 02-27-10, 10:46 AM
vwynn
vwynn's Avatar
+35 n 9.5 is really conservative.. easily fit with no rubbing what so ever.. itll just look like a regular car with regular plus size rims..
Old 02-27-10, 10:52 AM
kingbigs11
kingbigs11's Avatar
ok. So the 9.5 will even work up front then right?
Old 02-27-10, 10:56 AM
kingbigs11
kingbigs11's Avatar
and what do you mean it will look like a regular car?
Old 02-27-10, 01:18 PM
SorrGwa
SorrGwa's Avatar
should work, fronts may just barely barely rub depends how low ur car is, if uve removed the front fender edge cover. fronts seem to have a couple spots of thick fender tabs which it may rub if ur car is too low.
Quick Reply: Need an Answer ASAP
