How to change liscense plate bulbs GS300?
Remove the inside liner of the trunk and you have direct access to the bulbs. I hope this help.
Yes, you have to remove the trunk liner. The plastic inserts have a tunnel thru them, I used a flat head screw driver inserted in the tunnel to pry them out. The only tricky part is removing the plastic cup/tray around the "safety release handle". Look inside the cup and you will see 2 small slots, I used a small flat head screw driver inserted into the slot and one side popped out, just be gentle and don't force the issue.
mydakrri
03-05-19 11:09 AM
mberrett
08-01-11 01:07 PM
rsg
12-28-06 08:17 PM
