HELp me i only got heat on the passenger side
hey can anybody help me out my GS is only blowing hot heat on the passengeer side but on the driver side them climate control up to 85 and still blows cold HELP!!!! and why is that my GS fogs up so much LMK
is your DUal climate control Vents, located somewhere under your steering wheel, sorry cant help you with exact location, i just stood there while my mechanic went under there and flicked something? hope that helps! dont worry its not a major cost issue!
or you can just turn all the passegener vents toward you and call it a day! ....j/k
https://www.clublexus.com/forums/gs-...vo-motors.html
if you don't feel like paying $100 for a servo motor brand new from toyota, you can take apart your servo motor and just replace the electric motor inside. make sure you calibrate it.
oh, mine didnt need calibration.....although i am still having a issue with the mode part as my a/c box DOES have broken teeth on it and i will need to replace the a/c box , keep telling myself when i do my interior change
