Falken 452 tires ? bubble inside of tire
Old 12-01-09, 03:26 PM
MSOxGs3
MSOxGs3's Avatar
Default Falken 452 tires ? bubble inside of tire
Went to get my tires flipped today. Fronts were done than, ran into a problem w/ the rears. Tech said there was a bubble on the inside of tire and 2 nails. WTF.! luckily they prorated my tire. Is this a common problem w/ Falkens 452's?
Sit'n on 255/30/20's (R)\/\/0rks.
Old 12-01-09, 03:29 PM
speedaddic
speedaddic's Avatar
I see posts all the time about people with 452's bubbling. I've had mine on for 2 years with no issues. although I noticed you said you had nails in them. If you run on these tires with low pressure, they will get bubbles.
Old 12-01-09, 03:46 PM
5t341th
5t341th's Avatar
bubbles are common in many 452's i see
Old 12-01-09, 03:47 PM
Baliztik
Baliztik's Avatar
452's were notorious for bubbles and blowouts. The newer ones seemed to be fixed.
Old 12-01-09, 04:02 PM
Kyle Harty
Kyle Harty's Avatar
It seems that the 452's bubble easily when stretched, I've had them on my GS the last 2 summers but mine aren't stretched. I did have the sidewall shred on one of my rears last year but I can't say it was the tires fault, never know if it was losing air and running low pressure at the time of failure or something like that.
Old 12-01-09, 04:16 PM
vwynn
vwynn's Avatar
gotta note that most guys that stretch tires.. are running an overloaded setup.
Old 12-01-09, 04:18 PM
PHML
Master Thread Closer!!
PHML's Avatar
bubbles can occur on any tire.
my buddy had them on his dunlops...near the edge of the treads and sidewalls meet.....he hit a pothole...and that was it.
Mesca
Mesca's Avatar
I also recently had to change my FK452's, put on about 10k miles and there were 2 bubbles on the inside tread.
Old 12-01-09, 04:38 PM
MSOxGs3
MSOxGs3's Avatar
Thanks for all your inputs.
Old 12-01-09, 09:33 PM
aristo2369
aristo2369's Avatar
Default .........
FK452's really suck..... stretched or not....
i had 4 sets of wheels with nitto... continental... Bf's and the only tire i had problems were the 452's i its not a good time.... if i can go with any tire i would go with continentals... not too soft and not too noisy and great grip...
Old 12-01-09, 10:09 PM
geeznuts
geeznuts's Avatar
I had FK452s on my lowered Tacoma for over 4 years with no problems... But I run high pressure on my tires...
Old 12-01-09, 10:20 PM
aristo2369
aristo2369's Avatar
whats PSI that? i run 42 psi on my tires... they note on tire 50 max psi...???
Old 12-01-09, 11:25 PM
chrispy
chrispy's Avatar
FK452's are the worst tires ever. They will bubble even at high PSI.
Old 12-02-09, 04:59 AM
speedaddic
speedaddic's Avatar
I run mine at 45psi...haven't had a problem.
Old 12-03-09, 11:45 AM
geeznuts
geeznuts's Avatar
always 45-50psi
Quick Reply: Falken 452 tires ? bubble inside of tire
