First time lexus owner, possible problem with steering wheel has free play/movement
Old 10-24-10, 01:20 AM
  #31
aijoju
aijoju's Avatar
Argh! I changed my snow tires on and now the wandering is almost unbearable again. At higher speeds I have to steer the car all the time. It was much more stable with wider tires. I bought this car from Germany and at the time I didn't notice anything special. When I got back to Finland it was obvious. Germans have a lot smoother roads than we do. I'm so pissed that I might change the caster arm bushings...
Originally Posted by sakataj
pics for the visualizers
I'll try to get some soon.
Old 10-24-10, 06:15 PM
  #32
benbuilt4u
benbuilt4u's Avatar
i had this problem ended being my steering rack. rack wasnt leaking but had excess wear at the main shaft probably from being so low.
Old 10-24-10, 08:15 PM
  #33
pizdets17
pizdets17's Avatar
I have this issue too and my car only has 60k on it.. No wear at all, staring at the bag of daizen bushings in the corner for a month now..They scare me. Might get pissed off enough to change them...Sooon...
Old 11-03-10, 09:40 AM
  #34
aijoju
aijoju's Avatar
I took the picture finally!
Pros: Removed the clunking sound at rough gravel.
Cons: Didn't remove the steering wandering...
Old 11-04-10, 10:46 AM
  #35
sakataj
sakataj's Avatar
bout time lol....just looks like some hanging strap though
Old 11-04-10, 11:24 AM
  #36
aijoju
aijoju's Avatar
It's not just hanging, it's bolted to the brake pedal support frame. The "strap" is is a very thick piece of metal, so the steering axle doesn't move at all when you grab it.
Old 11-04-10, 11:50 AM
  #37
sakataj
sakataj's Avatar
well it looks like what we call "plumbers strap" or "hanging strap"
all good though thanks for the pics
Old 09-29-11, 02:43 PM
  #38
cmara2k9
cmara2k9's Avatar
Im having this same issue right now and i hope this fix works
Old 10-04-11, 01:14 PM
  #39
sakataj
sakataj's Avatar
bringing some duct straps home from work and will try this, this weekend
Old 11-18-11, 05:58 AM
  #40
ThomasGS4
ThomasGS4's Avatar
Brian, did you ever install the strap? I wouldn't mind using something a little more durable than zip ties.
Old 11-18-11, 11:45 AM
  #41
sakataj
sakataj's Avatar
no, you know me always busy and always behind....plus im waiting to see what FIGS solid steering rack bushings do for us (it should be coming up on close to being done in the next week or two i think)
the "zip ties" i use are industrial ones for HVAC
http://www.johnstonesupply.com/store...ep?pID=G80-002
they have a Tensile Strength of 175lb so they should be more than adequate.
Old 11-18-11, 02:49 PM
  #42
ThomasGS4
ThomasGS4's Avatar
Those look to be the same ones I use. Let me know if you ever do install the strap.
Old 11-18-11, 03:29 PM
  #43
vwynn
vwynn's Avatar
the bearing idea looks real good. just gotta find the correct ID to fit the shaft... n then remove everything so u can press/slide it on lol
Old 11-18-11, 05:35 PM
  #44
vwynn
vwynn's Avatar
have a feeling someone could capitalize on this if they make a DIY kit thats easy to install. just saying. giving you young entrepreneurs a hint
Old 11-18-11, 09:53 PM
  #45
D-Boi
D-Boi's Avatar
Figs needs to make some caster arm bushings so we can take a doodoo on tm engineerings websitr we robbig so many of us. Any idea how much figs' setup will cost?
Quick Reply: First time lexus owner, possible problem with steering wheel has free play/movement
