Is a aristo vvti head the same as a....
Old 11-05-09, 06:57 AM
sck_GS300
sck_GS300's Avatar
Default Is a aristo vvti head the same as a....
hey guys i wanted to know if a vvti twin turbo aristo head the same as a stock 2jzge please someone help.
Old 11-05-09, 07:49 AM
Mr Jokster
Mr Jokster's Avatar
Cool question, I'd like to know. ALSO, are there any benefits to doing that head swap? Do they breath better? Bigger valves? anything?
Old 11-05-09, 09:23 AM
sck_GS300
sck_GS300's Avatar
the reason i ask is because im getting a head for free and i wanted to build it...
Old 11-05-09, 05:32 PM
GS FONZy
GS FONZy's Avatar
Not a 100% sure, but from what I have seen and know, I would have to say no. Sure it will bolt uo to the block, but I think that is it. Now lets say you mod the GE manifolds to make them bolt on the GTE head. But, one more issue. The valve system is way different from the GE head, so you would probably have to run a stand alone because the GE ecu will not work with GTE head.
Old 11-05-09, 08:36 PM
99 GS3
99 GS3's Avatar
https://www.clublexus.com/forums/per...-question.html
Old 11-06-09, 12:15 AM
JeffTsai
JeffTsai's Avatar
No, they are different. Either head is interchangeable on the 2JZ block. However the GE and GTE heads have different intake and exhaust port shapes. The turbo head has narrower ports for higher velocity to spool the turbo. the NA head has smoother larger ports for better flow. They also have different bolt patterns and port spacings.
grumpi300
Performance & Maintenance
23
12-06-15 02:27 AM
wth98sc
SC- 1st Gen (1992-2000)
05-21-14 10:56 AM
Deception
Performance
14
10-03-11 08:45 PM
papodotcom
10-23-07 10:40 AM
Quick Reply: Is a aristo vvti head the same as a....
