Clips
Clips
Hi everyone,
I ordered some license plate LED's and it should be coming soon. I was looking at the underside of the trunk and I don't know how to remove the black plastic clips that holds the carpeted trim. Can someone explain please?
Also, how to remove the plastic dome, courtesy and trunk covers?
Mahalo for your help.
if you dont want to get the "expensive" tool:
Get a set of needle nose plyers insert under panel (open) one point on each side and rock up and down (point to handle, point to handle) and wedge it at the same time. Its a short process and it will pull it out, as for the ones in the middle, when you pull carpet a bit, with a little tug they can sometimes fall out with the carpet (keep an eye out for it so you dont lose it) sometimes the clip will stay in and just go right through the hole in the carpet, in which case you can use the same method as you did earlier with the outer clips but this time no carpet in the way
a zip tie....yes a zip tie. slide it under there and then pull from both straps. perfect. although i just bought some plastic interior pullers for cheap
Ronstitt
04-04-16 05:25 PM
Lex Luga
02-06-11 06:46 AM
Static911
08-04-01 10:23 PM
