GS430 common problems to expect - Just replaced power steering pump
Old 08-18-09, 10:23 AM
SMC
SMC's Avatar
Default GS430 common problems to expect - Just replaced power steering pump
I've an '01 GS430. This is my second Lexus with power steering pump replacement, the previous one was a 98 LS400.
I'm curious if this is a common problem on the Lexus with 150,000 miles? Also, what other problems can I expect from this car?
Old 08-18-09, 11:29 AM
raytseng
raytseng's Avatar
how did the pump fail? (A)leaking/losing fluid or (B) stopped working but plenty of fluid?
If it is the case (B), did you regularly change the fluid?
I do know the 1stGen LS400 had design problems with the power steering-one of the vaccuum valves sticks open and sucks fluid. Check in 1st Gen as I think it's one of the stickies.
However, I haven't noticed a pattern (based on posts here)to any of the other models.
Old 08-18-09, 11:34 AM
SMC
SMC's Avatar
Ray,
It's case A.
I hope this is not a pattern with Lexus, don't wish to do this with my 01 LS. Also, hope that it's not a particular way that I drive which causes this.
I'm also curious to find out if there's any other problem I should anticipate with GS430 at 150K miles.
Thanks
Old 08-18-09, 05:15 PM
qgoat
qgoat's Avatar
Had to replace mine last year at about 170k on the odometer. In my opinion, 10 years and 170k is pretty decent longevity for a ps pump. Also had to do my ac condensor about the same time so now I'm ready for another 170k.
Old 08-18-09, 09:00 PM
GS4_Fiend
GS4_Fiend's Avatar
P/S pump failure is caused by not changing the fluids. It uses ATF. Should change every year. If it's leaking, and you want a cheap fix. Try using the Lucas Power Steering stop leak. It works. GL.
Old 08-18-09, 09:07 PM
GSteg
GSteg's Avatar
My power steering was also leaking slightly. Used Lucas PS stop leak and it worked. No more leaks at all and the power steering still functions like normal.
Old 08-05-11, 04:19 PM
cwg292
cwg292's Avatar
I am about to purchase a 2001 gs430 wanted to get a opinion on this vehicle?
Old 08-05-11, 05:23 PM
GS4_Fiend
GS4_Fiend's Avatar
If you don't know much about cars, before buying the car you can take it to a mechanic and pay a small fee to get an overall check up. Common problems on these cars is that they got ball joints failure, wheels shaking vibrations problems, and such. If you search more you can see other people's issues.
Old 08-05-11, 06:32 PM
Big Mack
Big Mack's Avatar
Wink
Originally Posted by GS4_Fiend
If you search at all you can see other people's issues.
I think that's what you meant to say, right?
Please don't dredge up old threads to ask questions like this. You became a member and the search button works from day one. That said, his advice is solid.
Big Mack
DMPesso
10-20-16 12:10 PM
cmanns
11-29-14 11:28 PM
rx3scrappy
22
03-22-10 06:17 PM
billj747
16
01-21-08 10:53 AM
boris
12-15-07 12:16 PM
Quick Reply: GS430 common problems to expect - Just replaced power steering pump
