Installed Exact Motorsports front camber spacers, but got question now about height?
Old 05-25-09, 04:29 PM
SorrGwa
SorrGwa's Avatar
Default Installed Exact Motorsports front camber spacers, but got question now about height?
Installed the camber spacers, followed the instructions, everything torques down (first to 90ft lbs, then to 120ftlbs according to the instructions)
the issue now is, i guess i didnt notice it so much before, but when adjusting the coilovers, i had to crank the passenger side front quite a bit higher than the driver side front.
so the question is, is the GS pretty balanced in weight from side to side?
if not, what could be the issue? i saw no leaks, so not a blown shock.
Im running tein SS coilovers.
thanx for any help
Old 05-25-09, 05:59 PM
PHML
Master Thread Closer!!
PHML's Avatar
dang...dont tell me you torqued to 120 ft/lbs? did you see the thread in the suspension section about the bolt that snapped due to 120 ft/lbs torque?
as for coilover height....i do notice that tein coilovers do not give same heights for same level of coilover drops....this happened on my CS v1 before one of them blew out.
Old 05-25-09, 07:36 PM
SorrGwa
SorrGwa's Avatar
i followed the instructions that were provided by exact motorsports.
torque them to 70 ft lbs, then torque them to 120 ft lbs.
Old 05-25-09, 07:55 PM
SorrGwa
SorrGwa's Avatar
just read the thread in the suspension forum about the snapped bolts.
i did find it a little weird that they asked to torque to 120ft lbs. thats usually a number set for head studs.
i think ill back them off tommorow and retorque them to 105 or so. i rarely seen any bolt need to be torqued so high.
Old 05-26-09, 05:18 AM
JiBBeL
JiBBeL's Avatar
The GS comes a lil lop-sided straight from the factory to compensate for the driver. It's normal.
Old 05-26-09, 06:18 AM
habeeb89
habeeb89's Avatar
I have always noticed this, just thought I was crazy
Old 05-26-09, 06:38 AM
SorrGwa
SorrGwa's Avatar
Ok, thanx guys, was just a little concerned. cuz the front passenger side was off by 1/4 inch with both front coilovers at the same height...
Old 05-26-09, 07:10 AM
GS300ToM
GS300ToM's Avatar
got specs on your front camber & toe yet??
Old 05-26-09, 08:48 AM
vwynn
vwynn's Avatar
hah mines lower on the driver side.. sigh =[
Old 05-26-09, 08:52 AM
LEXUS_KID
LEXUS_KID's Avatar
Any pictures
Old 05-26-09, 09:31 AM
SorrGwa
SorrGwa's Avatar
Ill have pics and spec numbers to work with once i get the car back from alignment.
i spent yesterday installing the camber spacer blocks, and quickly adjusting the height to make up for the 1inch extra drop. im gonna spend today fine tuning the height.
i know that from ground to fender, i need a minimum 25 3/4" to be able to clear the driveway to my place (stupid condos). At this height, i just scrape the front lip when i rush out. So im hoping to bring the height to 26" fronts (fender to ground) and 26 1/2" rears (fender to ground). Wish i can go as low as some of the guys on this board, but getting into the parkade is more important for me.
For now, she sits with a little gangsta lean, or a permanent invisible fat chick in the passenger seat.
this was a shot from a few months back.
Old 05-26-09, 10:29 AM
JiBBeL
JiBBeL's Avatar
that's lookin real nice man
Old 05-28-09, 12:35 PM
SorrGwa
SorrGwa's Avatar
back from the alignment shop, here are the specs:
- tein ss coilovers
- daizen front rear sway bars
- rear spc camber kit
- front exactmotorsport camber block spacers
Lowered from ground to fender:
Fronts: 25 1/2"
Rears: 26"
Front
Left: -1.75 degree camber / +7.78 degree caster / 0.12" toe
Right: -1.78 degree camber / +7.71 degree caster / 0.09" toe
Rear
Left: -1.25 degree camber / -0.06" toe
Right: -1.21 degree camber / -0.09" toe
Old 05-28-09, 12:47 PM
GS300ToM
GS300ToM's Avatar
SorrGwa, are the toes in spec? idk the number on ttop of my head, thats how i want my lookin like in the low or mid -1.. what tires are u running again??
btw thanks for the update bro....
Old 05-28-09, 12:53 PM
macd7919
macd7919's Avatar
Do you know what grade bolts they sent you? If so you can calculate the torque needed for them, also if you over torqued the bolts too far already then you may have already taken them past the point of elasticity and you will need to replace them.
Quick Reply: Installed Exact Motorsports front camber spacers, but got question now about height?
