just want a quick response please....
i know that their has to be a thread for this but i don't have time to browse for it...but i was wondering what size tires you put on your 19'' rims???i just bought a new set of 19''s for my 02 gs430...what size tires should i put on mine???
staggered set: stern st-2
19x8.5 offset +32 (front)
19x9.5 offset +35 (rear)
person from the shop told me that i might have to put spacers for the fronts...is he right???and if he is what size spacer do i need...
please get back at me a.s.a.p. with your response....thanks
According to :
https://www.clublexus.com/forums/gs-...-05-sc430.html
19x8.5 245/35/19 in spec - yes
19x9.5 275/30/19 in spec - yes
19x8.5 245/40/19 in spec - no (fat setup)
19x9.5 275/35/19 in spec - no (fat setup)
that's the problem...im sitting on jack stands and i need my car to get around....i don't care if doesn't look right...i could deal with that...ill take a picture of the before and after...spacers or not????and on that forum that ZIPPY gave...the 19x9.5 it shows the right fitment for the tire is 275/35/19 but it also shows that its not the right one...that its a fat set-up...which one is right???
iModerate
I am not too sure about the offset and spacer stuff though
According to :
i think u should be good.... with +35 in the rear with that set up, refer to
https://www.clublexus.com/forums/gs-...n-gs3s-11.html
i've got +29 in the rear and i get about 3mm clearance... pic from the sig..
There would be no point to buying a spacer until you drop it. Spacers need to be measured out post drop to be correct. If you are going with a low drop than you should run the 35 series on the front and 30 on the rears, I run a stretched setup with 235/35 front and 245/35 rear
you have no idea CEELO...whats this site for again???i was just asking for a simple opinion...obviously you aint no help...so keep your negativity away...i dont need that *****...and for the rest i greatly appreciate your replies...thank you
Im running pretty much the same offset except i have 20's
20x8.5 +31 offset - 235/30/20
20x9.5 +31 offset - 255/30/20
no problems with the fronts/rears clearing. Except had to cut the rear fenders.
hope this helps
hope this helps
