HELP! sensor testing, vsc/vsc off, CEL
i have noticed these lights are an issue on a lot of posts (VSC, VSC off, and CEL), has anyone compiled a simple testing procedure for the various sensors. Can't you do a resistance test to see if sensors are working using a multimeter??? EX: Pin A and Pin C= X voltage? Since this is such a common problem this would be extremely helpful. Currently pulling codes p0120,p1121,p1128 thinking it's my tps (throttle position sensor) but I want to know for sure before i spend the money. Any direction would be appreciated.
https://www.clublexus.com/forums/gs-...cel-codes.html
Check your codes via DIAGNOSTIC block in engine bay terminal TC & E1 with a paper clip
Dash lights will all flash count the orange engine light only
http://bahamutcars.free.fr/workshop/...nts/index.html
Repair Manual / DIAGNOSTICS / ENGINE this will take you to engine fault code list
Follow the flow charts to fix
Sound like you have TPS issues (throtle postion sensor)
Check your emissions tag on under side of bonnet / hood if says OBD2 then this will not work you will need to use a scanner
TPS How to test
Repair Manual/ELECTRONIC FUEL INJECTION/THROTTLE BODY/ON-VEHICLE INSPECTION
TPS How to test
iModerate
TPS How to test
TPS How to test
Update- Still idling at about 1200rpm, vsc/vsc off lights illuminated. APPS resistance check good, can here throttle control motor turn on when APPS is moved however am not getting the right resistance from it(throttle control motor, multimeter doesn't move at all when proper connections are made), can't get to the TPS to do resistance check. What are we thinking out there???
99es300
17
07-17-06 08:11 PM
