Where to hook up my LED Side Mirror Blinkers...
Old 04-17-09, 02:23 AM
REV-01
REV-01's Avatar
Originally Posted by PHML
This is the correct way to do it so you save on wires.
Unfortunately when I did this mod like 4 yrs ago...I didn't have a probe.
yes that is the correct way to do it. it is not so much about wasting wires. but it is one of the reason i got into doing what i do daily. it will bother me alot if ran the wire and it can be found under the dash. it is not as "clean" you know what i mean.
plus i gotta save room for more other wires i need to run. save as much room as i can. it will bother me somemore if the carpet is starting to get thick by the sills.
Old 04-17-09, 04:06 AM
skperformance
skperformance's Avatar
Doesn't go by the sills since it is through the rubber hose loom with the rest of the wires right into the cabin so it is less wire than you might be thinking.
Old 04-21-09, 11:28 AM
TYPEII
TYPEII's Avatar
Can't remember, but does the side markers on the front bumper blinks... I have the L-Sportline bumper and never reinstall them back in when I did the switch...If they blink I'm thinking I could tap into those...help fellows.
Old 04-21-09, 12:13 PM
Spyder78
Spyder78's Avatar
No sidemarkers do not blink.
Old 04-21-09, 04:56 PM
JoelGs
JoelGs's Avatar
Need to go the other route since Nigel can't produce 01+up side mirror for our car...
Old 04-22-09, 10:44 AM
sakataj
sakataj's Avatar
i was wondering joel if we could use the base of the 1998-2000 and if it would bolt onto ours so we could use these
Old 04-22-09, 12:14 PM
2jzism
2jzism's Avatar
I was thinking the same thing, I wonder if the 98-00 mirrors would bolt up, and if the plug is the same as the 01+ mirror plug?
Old 05-04-09, 09:59 AM
sung35
sung35's Avatar
Originally Posted by TYPEII
Nigel LED Puddle/Blinkers—Got the puddle lights to work
Where did you tap to for puddle lights?
Any one has answer for blinker light wire to tap to? I am about to do mine.
Thanks.
Old 05-04-09, 10:05 AM
TYPEII
TYPEII's Avatar
Thanks.
For the Puddle lights, I tapped into the foot well lights, there are one on each side...For the blinkers I tapped into the rear tail light turn signal, my passenger side is working, but I have a Bad driver's side blinker, been in the process of trying to get a new one from Nigel...Hopefully, I can get a new one soon...
Old 05-04-09, 11:18 AM
Emackny
Emackny's Avatar
Here's what I did.. Puddle lights.. I tapped into the foot lights. Blinkers.. I tapped in the wires running to the rear on the floor of the drivers side and for the passenger side I had to run it to the blinker in the front (couldn't find a wire running to the rear).
Old 05-04-09, 01:09 PM
sakataj
sakataj's Avatar
u gonna be the guinea? i guess time to start searching for 2000 and below mirrors for cheap and experiment
KGeezzy
CT 200h Model (2011-2017)
07-21-17 09:11 PM
eross1981
HS 250h Model (2010-2012)
02-07-15 01:43 PM
Pkathee
09-06-12 02:04 AM
GS_OREO
03-19-10 09:37 AM
altersail
06-20-09 03:49 AM
Quick Reply: Where to hook up my LED Side Mirror Blinkers...
