DIY on changing servo motors - Page 4 - Club Lexus Forums
Thread Tools Search this Thread
Old 05-06-09, 12:15 PM   #46
2kaygs4
how much would this service cost, thats to much diy for me?
2kaygs4 is offline   Reply With Quote
Old 05-06-09, 01:07 PM   #47
sakataj
sakataj's Avatar
hahaha i promise it really is simple. i think (and im speaking from what they quoted me) labor is like 3-4 hours for both + plus parts so i think that would be like 300-400 in labor and like 300 in parts= so roughly 600-700....thats why i tackled this myself. it didn't take me but like 2 hours MAYBE. for me it was worth trying myself before dumping that kinda money to the dealer
sakataj is offline   Reply With Quote
Old 07-02-09, 07:34 PM   #48
Adam2562
Adam2562's Avatar
thanks for the write up.. this will help me
Adam2562 is offline   Reply With Quote
Old 07-02-09, 09:06 PM   #49
sakataj
sakataj's Avatar
Quote:
your welcome....good im glad. if you need anything just ask
Old 07-15-09, 11:24 AM   #50
lyonkster
Great writeup - but did you figure out what the problem was after replacing the servos (post #45)? I didn't see a resolution discussed, and I'd hate to replace mine and end up with them not working properly .
lyonkster is offline   Reply With Quote
Old 07-16-09, 04:49 AM   #51
joshoowa
joshoowa's Avatar
good write the noise we here that sounds like we got a mouse running around inside our ac vents, will replacing the mode servo fix this?
off topic: my mode servo broke on my 03' RX300 didnt know how to fix it but maybe I can look it up in the shop manuals.
joshoowa is offline   Reply With Quote
Old 07-18-09, 01:02 PM   #52
sakataj
sakataj's Avatar
Quote:
yes, the gear on my ac box is broke (the white box the servos attach to) i will fix it by replacing the box when i do my interior tan to black conversion
thanks and yes it will.....im fixing to tackle my drivers side which is annoying me now
no your not off topic....as far as i know the rx uses the same servos we do and they are JUST as prone to the problem as the gs is
Old 07-18-09, 01:55 PM   #53
UDel
A mouse running around inside the ac vent/cd changer area is a very good description of what I am hearing when first starting my GS after it has not run for very long. Strangely I was a little low on coollant and added some and the noise has gone away. It only happens sporadically, the ac blows cold air on both sides and it blows hot air on both sides. Not sure, if it ends up being a servo I will definitely change it myself and save the money but I am going to change it when it stops working, I can deal with the "mouse" noise as long as everything is working well.
UDel is offline   Reply With Quote
Old 07-18-09, 05:24 PM   #54
sakataj
sakataj's Avatar
Quote:
as i said in other post....if u hearing the mouse noise it is def a servo. mine would come on sometimes, go away, come back etc etc till i got annoyed enough to change it
Old 08-06-09, 02:38 PM   #55
MarkG2000
Was here to ket a handle on the servo stuff that's been talked about because I've had the problem for...say 3 years and was hoping it would just stop on its own.
I guess I was in a dream.
Anyhow...the clicking noise is actually training me for the loony house.
It seems that there are lots of assumptions as to which one it is and what it's called but
we all seem to have it.
To get rid of my noise..I turn the a/c on and turn the temp **** to HOT. This stops the clicking. Then after a few min...I slowly turn the temp cooler unit the clicking starts again. This is usually around...81 so I turn it up to 82 and no more noise.
Now....which "servo" is to be changed/fixed? thanks.
I also read that some are having what's considered a mouse like noise. For me it's like
it I hear water sloshing around. Real faint but it's a sound of also like it's chugging along.
clues anyone?
thanks a heap
MarkG2000 is offline   Reply With Quote
Old 08-07-09, 07:14 AM   #56
JiBBeL
clues anyone?
thanks a heap
I got the same problem on my new RX and my GS. It's air in the coolant system I think. I can "burp" the sytem and it'll be solid for a few days but always comes right back
JiBBeL is offline   Reply With Quote
Old 08-07-09, 02:23 PM   #57
sakataj
sakataj's Avatar
clues anyone?
thanks a heap
temp servo but i suggest changing both while your in there
Quote:
rx's and gs share the same servo problem. its not a coolant issue....its DEF a servo problem
Old 08-08-09, 11:33 PM   #58
MarkG2000
This is the servo # I have to replace. Haven't seen the part yet
to figure out which one in the pictures I need to replace.
Lexus quote about $700...WHAT!
anyway which Picture # is this particular servo?
Thanks
Old 08-13-09, 11:00 AM   #59
sakataj
sakataj's Avatar
87106 48020
Thanks
well if you look on the 1st post i gave the part #'s on the servos except the air recirculation servo but i tried crossing that part # you listed on sewell's page and no luck. so if i had to guess and again this is a guess i would say its the air recirculation servo and that pic is in post # 2 but where did you get this part #?
Product #:8710630341, Lexus OEM Damper (For Cooling Unit) Servo Sub-Assy, Quantity:1, Price:$141.31, Item Total:$141.31
Product #:8710630371 Lexus OEM Damper (For Mode) Servo Sub-Assembly, Quantity:1, Price:$143.38, Item Total:$143.38
and drivers side
here is the part # 87106-30351, Lexus OEM Damper Servo Sub-Assy
Old 08-13-09, 08:29 PM   #60
Adam2562
Adam2562's Avatar
ahh i think i need the drivers side for me personally
Thread Thread Starter Forum Replies Last Post
DIY on changing center console bulbs/tranny gear indicator bulb sakataj GS - 2nd Gen (1998-2005) 132 12-14-16 03:48 PM
DIY 2001+ LED Mirrors With Puddle Lights And Turn Signals sakataj GS - 2nd Gen (1998-2005) 146 05-18-15 05:27 PM
Well, I Failed.... sakataj GS - 2nd Gen (1998-2005) 43 12-16-11 02:22 PM
Well guys i totaled my car, goodbye GS hello LS sakataj GS - 2nd Gen (1998-2005) 47 04-04-11 10:41 AM
DIY on changing/cleaning cabin temp sensor sakataj GS - 2nd Gen (1998-2005) 8 02-04-09 06:12 AM
Tags
2004, 300, ac, clublexus, damper, dash, gs, lexus, lubing, motor, motors, recirculation, rx330, screw, servo, subassembly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
