A/C Blowing Hot Air
I think you just need to recharge the system. If you dont know how to do it take it somewere.
I am almost 100 percent sure it is the freon.
I had similar problem. It just seems to me you dont know how to fill the system. dont spend any extra money. Good Luck.
true dat. i haven't recharged a GS yet (and hopefully won't have to) but there should be two valves for putting in the refrigerant R134a I think, one upper and one lower valve. you need to put it in the upper one while revving your engine and blasting your a/c. may wanna have a homie helping you out. eventually your a/c should start getting cooler (be sure you've got the car set to a cool temp.).
i 2nd the notion that you dont know how to fill the system and you should take it someplace but i will try and help you if u wanna do this yourself.i had a similar problem in mine this summer it was blowing cold and mine was actually OVER charged....causing it to blow hot ait
Hey guys. I realize this is somewhat of an old thread, but I'm having a similar problem on my 99 GS400. When the car is moving, the a/c blows ice cold. When I stop, the air is luke warm. I took it to the dealership yesterday and they said I had two bad "read" valves, and that the compressor needed to be replaced (for $1,900, I might add). Something doesn't sound right to me. Why does the compressor work when I'm moving but not when I'm standing still? If I needed a new compressor, I would think that it wouldn't work at all.
Any thoughts? Thanks.
e
e
e
e
https://www.clublexus.com/forums/gs-...vo-motors.html
so i had 10 people a day making new posts bout servo's it was getting annoying when people EASILY coulda searched and saved the "space" and time
thanks, least someone gets it
Yes it blows air. When I am setting the temperature it starts blowing regular temp with air and when I set to the heater it works to the heater.
Any other suggestions.
Thanks
