A/C Blowing Hot Air
Old 07-08-10, 04:05 PM
  #46
poohunny
poohunny's Avatar
good deal...thanks sakataj! I guess I'm off to find a drier and expansion valve...I can't imagine these will be more than the ac compressor itself...
Old 08-20-13, 05:54 AM
  #47
damiendada
damiendada's Avatar
Hey here's an idea..... Does anyone think we can bypass the temp servos so that that A/C always blows cold. I ask because the servos only move arms so if those arms were in a fixed position out of the motor in tern wont the ac always be at one temp weather cold or hot? I ask because my is HOT AS F*%K, and I hate it. I live in the Bahamas and its always hot so I have no need for the heater at all. If it can be done someone let me know the fixed position of the arms please im not sure how they flow exactly because I have never seen mine work.
Old 08-20-13, 02:06 PM
  #48
damiendada
damiendada's Avatar
no one has feedback for me on this man....
Old 09-18-13, 12:24 AM
  #49
salimshah
Forum Moderator
salimshah's Avatar
Received 1,105 Likes on 994 Posts
98 GS400 A/C stopped cooling.
This is what I observe:
With AC swtich on and thermostat at low setting, the engine goes to fast idle. I can see the AC clutch engage and the pressure plate starts spinning. No weird sound at all ... except the engine rpm is higher as the engine does not see the compressor load.
Strange to me was that with engine turned off, I can spin the pressure plate with very little resistance by finger tips. I expected the pressure plate to be rigidly connected to the center shaft of the compressor through the center bolt. To me it does not seem normal.
Thoughts?
Salim
Old 09-26-14, 07:38 AM
  #50
Kretek234
Kretek234's Avatar
Default AC blowing warm air.
Originally Posted by sakataj
ok so then the heat side works on BOTH sides (my heat when my servos were bad only worked on one side)
run through all modes while sitting in the passenger seat and see if all modes function correctly and then do this also for the a/c see if it on passenger side it works. this will help narrow down a servo and a actual a/c problem.
have you actually had your a/c serviced or checked?
Hi, I'm new on this forum, after I read this forum, I have similar problem. My '99 GS 300 AC all sudden the next day blowing warm air. Check the manual, the AC button solid green, not flickering, check the clutch is engaged.. I bought AC Pro recharge kit, come with gauge. Before I recharge it I plug in the gauge to the low pressure first, the needle shoot up to red zone, I try this several time, but is always in the red zone, so I don't recharge the unit, since I have no experience with AC, I'm afraid to overfilled. I checked all the button mode all working fine, before this the AC always blowing very cold air fast, the manual says if the AC button flickring, that means problem with compressor. But mine is solid green no flickering. Any thought and advice to solve this problem I really appreciate it. Thank you.
t2014rx
RX - 3rd Gen (2010-2015)
08-14-14 09:19 AM
jcoukos
01-04-13 05:02 AM
ancdmd
08-15-10 08:18 PM
jholem1
05-08-10 01:31 PM
Quick Reply: A/C Blowing Hot Air
