How To Install Rear View Camera
Old 11-14-08, 03:24 PM
ny888
ny888's Avatar
Default How To Install Rear View Camera
Anyone have links to pictorial instructions on how to install a rear view camera in the 2GS? Not sure how to install a trunk camera as well as how to snake the wires to either a VAIS unit or a rear view mirror with monitor.
Old 04-07-15, 03:56 PM
Foob
Foob's Avatar
Bringing this post back to life because I would also like to know! Can't find any help on the forums from older posts. I've got the Esky EC170-06
Old 04-07-15, 08:59 PM
Mr Jokster
Mr Jokster's Avatar
Well wiring is gonna be a sinch, just like running any wires through a vehicle up to the deck. Run it through the already there plastic on the trunk hinge (same route for the wires for the trunk brake lights and license plate lights). As for mounting, well its not a flush mount set up where you'd drill a hole the size of the camera and flush mount it. best thing probably would be to mount it in between the 2 license plate lights, the Esky has 2 mount holes, so just use some short self-tapping screws to mount it. To run the wires, you can remove one of the license plate lenses and maybe shave/file down just a little off the side of the square mounting hole that is there so the Esky wires will go through and be sealed when the plate light is re-installed.
Old 04-07-15, 09:17 PM
Foob
Foob's Avatar
Oh alright. Yea I was thinking of somewhere right in the middle, and will shave some off the licease lense out to run the wiring through then when everything is done might seal it up with some clear Silicone to avoid any water getting in the trunk.
Thanks J Once again lol, you have been helping me with everything with this project so far. And I REALLY appreciate it!
Old 04-07-15, 09:21 PM
Mr Jokster
Mr Jokster's Avatar
NP, I enjoy helping, just as long as I dont make a mistake, as I made a couple this week Silicone is a good idea. Also, if not self tapping screws, you can mark off where the mounting holes are just drill all the way through and use a nut and bolt for a good seal. Self tapping screws could eventually fall off.
Old 04-08-15, 12:56 PM
nelson09
nelson09's Avatar
Key hole in the trunk garnish above the plate!
Old 04-08-15, 10:30 PM
Foob
Foob's Avatar
Yea, but I've heard quite a few people having fitment problems with their camera being too big for the hole. (no pun intended) though the wiring would be super easy to run just straight back, I have already ordered the kind that mount onto the car, someone else wanna show us how easy/hard this method is?
Old 04-08-15, 10:31 PM
Foob
Foob's Avatar
and yea, I'm prob gonna go the nut and bolt route, thanks for the heads up!
Old 04-09-15, 05:15 PM
dungut
dungut's Avatar
This is from eBay. All metal housing. Looks close to how an oem would be. No room inside license plate trim to flush mount a camera.
As you can see, I can see my bumper, which is a huge help when trying to get close to a wall or car when reversing.
BHustle84 (10-08-21)
Old 04-09-15, 08:17 PM
Mr Jokster
Mr Jokster's Avatar
This is precisely my suggestion good pic
Old 04-09-15, 09:14 PM
Foob
Foob's Avatar
Extremely clean install, best I've seen on a Gen2 gs so far!
Old 04-10-15, 02:12 PM
karolgt
karolgt's Avatar
Foob and how you conneced this camera to build-in screen? do you have navtool?
Old 04-10-15, 09:26 PM
Foob
Foob's Avatar
karolgt
I don't have the navigation with my system I'm getting a new Aftermarket headunit. Typically in an aftermarket system there are two yellow ports to plug in video from the camera to the headunit. LIke for example in the headunit I'm planning on getting see on the right side of the rear.
Also I don't have NaviTool. But I found this on their website if it helps: http://www.navtool.com/lexus_GS_98-00.aspx
Old 04-13-15, 03:45 PM
PandaGS300
PandaGS300's Avatar
Hey didn't see this on eBay, do you remember the seller or item number?
Old 04-14-15, 06:20 AM
lostape45
lostape45's Avatar
How does this hook into the factory nav system?
Quick Reply: How To Install Rear View Camera
