Help! Please Read!
Help! Please Read!
I just got a full inspection yesterday at Lexus and here are the problems they found, I'm not sure if everything they said is actually bad since I know dealership service always tries to rip us off...
1. fluid changes with timing belt and waterpump $2400
2. rear main seal is leaking $2100 (they said it's very minor and told me to pay attention to the leakage, could run for about 10k-15k miles.
3. right front outer tie rod ends need replaced $235
4. four wheel alignment $129 (after #3, they have to do it they said)
5. fog light connector $65
Anyone knows where can I get cheaper parts and if it's recommended to get these parts fixed by my local mechanic (he has worked on vdub all his life and specialized in german cars like audi/bmw, i got my bank1O2 sensor fixed there)
Please help! thanks!
Ouch!!!!!
Well I can tell you that you can get the tie rods and lower ball joints from TM engineering for the same price the dealer gave you for just the tie rods and do them yourself. You will need an alignment but find a reputable local shop that knows what they are doing. Also, if you get a 4 wheel alignment, ask them if they jack the rear up to adjust the toe. On our cars, if they do not release the weight it can cause issues and even damage the adjustment areas. Good luck with the rest of it.
the alignment was about the only price quote even close to what a local mechanic might charge. i gots all the fluids done + timing belt & water pump for like 800 i believe, back in CO like 2-2.5 years ago. this is recommended to be done at like 60k i think for the gs400, not sure.
Local mechanic charged me $800 for the 90k service last August (07). Did everything the manual recommends for 90k. $800 was with parts.
Tie rods are not hard to replace, just make sure you get a good alignment after you are done. Find a frame shop or an old school alignment guy to do the work. Don't let one of the chains do it. Not enough experience to do it right in my opinion.
CL members get a discount at Sewell Lexus. Also, if you have the part numbers you can order the parts through a Toyota dealer and they are usually cheaper than from Lexus.
http://www.automotivelightingusa.com...oducts_id=1246
is this a foglight connector? if so, should i replace it or just connect it to the old one since only one side is sometimes out. when i open the foglight and mess around with the connector, it sometimes work.
What shop was this ?
Daaang. That's a lot of money. I just did the 90k service for someone last week for $800. I used genuine Toyota parts(water pump, front main crankshaft oil seal, both cam seals, acessory belt, thermostat, timing belt, timing belt tensioner, timing belt idler pulley, spark plugs, and all the associated orings and gaskets). The guy got a awesome deal lol. It was about 1/3 of what the dealer was asking for the same list
It only took me 3-4hrs to finish all that work and it was in my garage. I know the Lexus dealership can do it faster. Not sure why the heck they charge so much for it.
coco-bun, i actually live in bloomington, IN...but i have no problem coming up to indy. I just hope it can be done fast and cheap, oh i need to do the 90k service as well, please recommend me some local cheap places.
lexus-parts: yes, please pm me the prices i can get them for. i appreciate it. thanks.
Chuckli, you should tell us which year model Lexus you have, and the mileage on it.
Timing belt and water pump are $1000 job including parts at a local repair shop. Main seal is around $500. Both outer rods are $200-250 (including parts). Don't replace just one, they both wear out evenly, and chances are the other side will wear out soon as well, and you will need another alignmnet, which is another $60-100.
