90 K Maintence and leaking water pump
Old 09-10-08, 08:11 AM
KurtK
KurtK's Avatar
Default 90 K Maintence and leaking water pump
Hey Gang,
Took my 1999 GS 400 with 86,000 miles into the Toyota Dealer. Orginally was just going to get a tune up after reading countless threads about the pros and cons of doing a "major maintence". Change out the water pump with the timing belt?..no they last a long time ..why replace a good part...etc. Opted to get the timing belt and water pump done and requested the serpentine belt as well. Orginal estimate for t belt, water pump, and tune up was $1,090. Not too bad I thought. Got a call a few hours later with the news the water pump was leaking(they took pictures on a cell phone) so it was a good call to have included that. Also said I had heavy build up of carbon and crap in the fuel injector system and throttle something or other ($65) to clean that up. They said tensioner belt and idler pulleys not noisey but my call as to whether to change them out too( sure why not what's another 2-300$) as long as they have my baby torn apart. Asked about cam seals and was advised those don't often leak and if a seals sealing ..leave well enough alone ( so I did). Final bill $1619. All OEM parts new plugs yada, yada. Service manager also advised against Toyota Red antifreeze as it has salt in it that will actually hasten leaks even though I read threads by people praising it's vitures as a great lubricator and protectant. So that's my story. Glad I didn't wait another year or 10,000 miles even though the car was running perfectly. I had bought it last year and had only sckety service records on it. So I figure ( hope!) i'm good for another 10 yrs of happy trouble free hauling ***!
Old 09-10-08, 08:40 AM
JeffTsai
JeffTsai's Avatar
That's weird for the dealer not to recommend the factory Toyota antifreeze. I wonder if they made up an excuse just to make more money. Also, it's highly recommended to do all the seals while you're in there. It's all right there and readily accessable. The seals are rubber and WILL give out eventually over time. I usually change them out when doing a timing belt job. It takes at most an extra 20-30minutes and costs about $30-40 for the new seals.
Old 09-10-08, 12:03 PM
UpstateLex
UpstateLex's Avatar
Jeff how do I find more pics of your car bro, **** looks ill.
MellonC00
Hybrid Technology
01-02-19 09:17 AM
GibbsLexus
08-09-17 07:18 AM
Harvey99
05-30-15 08:04 AM
WB03LS430
12-09-08 08:49 AM
zach
01-08-07 05:21 AM
Quick Reply: 90 K Maintence and leaking water pump
