car was jumped backward
Gs400 (not mine) was jumped backward and blew all the fuses. fuses were replaced and relays were replaced. fan blower for A/C doesn't work and door locks are acting up when locking, it unlocks. anyone know what the problem could be. ???
thanks in advance
thanks in advance
*****. now you have to trace through all your wiring, check all the fusable links, and run tests on your ECU and TCM. As far as the door locks you probably just have to reprogram them or something stupid. Look around and see if you can find out how. The AC fan blower is probably a more serious problem, if the fan was on when it was jumped backwards, being that the hvac is one of the first things to start up when going through accessory power, the motor could be fried, or it could be the actual hvac display/control unit that's fried and not sending the proper signal to the motor.
chances are you will need a new pcm and/or tcm
if you know someone w proper diag. equipment, shoot them a 12 pack and have them check it out for you.. good luck though.
and yeah, actually jumping a car with the polarity reversed has a similar but much smaller scale effect as the car getting struck by lightning.
if you jump the car backward worst thing can happen is your whole eletrical get shot... since you replaced all the fuses and relays and still acting weird sounds like your ECU is gone too. i had couple vehicle that was jumped backward somebody try to start the car all when to the dealer and replace the ECU.
RedRacer
04-14-06 01:14 AM
