A/C code help
Old 03-12-08, 11:28 PM
pitmanr200
pitmanr200's Avatar
Default A/C code help
Ok i fulled with my a/c some more today and did diagnostic on it. It needs freon I know that. but I was looking to see if there were any error codes. I got 21 23 24. now 21 and 24 are because it was dark outside. 23 is a pressure switch circuit so what does that mean is bad. I hope not compressor or could it just be there is no freon in it.
Old 03-13-08, 08:25 AM
pitmanr200
pitmanr200's Avatar
no body has seen this code before.
Old 03-13-08, 06:07 PM
sockfocks
sockfocks's Avatar
usually codes are preceded by a P0XXX, not sure what 21, 23, 24 mean. How did you get these codes?
Old 03-13-08, 10:02 PM
pitmanr200
pitmanr200's Avatar
not a engine code. this is the diagnostics on the climate controll. you access it by simulateously pushing auto and air circ and turning ign to on. it will give you codes.. on what is wrong with a/c
Old 03-13-08, 11:40 PM
Debonair
iModerate
Debonair's Avatar
Default Dtc 23
*** You did not put a Year or Model/Engine above - This info is listed for a 00 GS300 but covers both engines - Use at your own risk***
CIRCUIT DESCRIPTION
The pressure switch sends the appropriate signals to the ECM when the A/C refrigerant pressure drops too low or rises too high. When the ECM receives these signals, it outputs signals via the ECM to switch OFF the compressor relay and turns the magnetic clutch OFF
Attached Thumbnails A/C code help-23.gif
Old 03-13-08, 11:41 PM
Debonair
iModerate
Debonair's Avatar
Wiring Diagram
Attached Thumbnails A/C code help-wd.gif
Old 03-13-08, 11:44 PM
Debonair
iModerate
Debonair's Avatar
Diagnostic Step #1
Attached Thumbnails A/C code help-step1.gif
Old 03-13-08, 11:45 PM
Debonair
iModerate
Debonair's Avatar
Diagnostic Step #2 - #4
Attached Thumbnails A/C code help-step2-4.gif
Old 03-14-08, 12:30 AM
pitmanr200
pitmanr200's Avatar
thanks alot. it is a 98 gs400, that makes sense being its out of freon. that i why it is throwing that code to shut compressor off so it doesnt burn up due to no lube.
dadewi
GS - 1st Gen (1993-1997)
12
10-22-18 12:45 PM
jasawh
02-24-18 06:29 AM
diverchris
12-27-10 07:43 PM
Max Power
08-24-09 04:06 PM
opsta
07-27-06 09:33 PM
Quick Reply: A/C code help
