98 gs400 timing belt kit Part #'s
Old 03-11-08, 10:17 PM
pitmanr200
pitmanr200's Avatar
Default 98 gs400 timing belt kit Part #'s
Ok i am going to get my parts for timing belt change. I just want what is necessery, like tb, wp, serpintine, belt and so on. If you can give me a list of what has to be changed and what should be checked like cam seals tensioner or what ever. Tried searching, but find gs300 not 400. will propably get from carsons so im getting price list together. Dont really understand the idler pulleys. is there just one that needs to be replaced or two and all these different tensioners. I quess im just confused.
Old 03-12-08, 12:01 PM
TRD911
TRD911's Avatar
You did not search very hard. Here is a thread that just came up a while back.
https://www.clublexus.com/forums/sho...d.php?t=338763
BP
Old 03-12-08, 12:52 PM
19psi
19psi's Avatar
try this:
http://cgi.ebay.com/Timing-Belt-Wate...QQcmdZViewItem
Old 03-12-08, 01:05 PM
pitmanr200
pitmanr200's Avatar
Originally Posted by 19psi
Yea I checked that one out Kai. but I got quote from carson toyota for like 230 or 240 shipped. That was with tensioner, but not idlers. Didnt have as much as that kit, but some of that stuff I may not need. Im going to go the oem market I beleive after seeing not much different in price. carson was with tb, wp, tensioner, crank seal for ls470 i hope that works, and serp belt. Let me know if you think i need anything else or if you can get a better price. If the cam seals are bad. I will just goto local dealer and get them. they arent very pricy.
Old 03-12-08, 05:07 PM
19psi
19psi's Avatar
ok, that sounds like a good deal with carson. i'm pretty sure i can't get oem parts that cheap, the dealer won't come down that much!
Old 03-12-08, 09:38 PM
pitmanr200
pitmanr200's Avatar
so what all do you think i must get. if cam seals are bad i will get them then if not let em fly.
here is my list
timing belt
tensioner
water pump
crank seal being you have it off anyways
serpintine belt.
dont know if i need anything else. Any suggestions let me know.
Old 03-12-08, 09:44 PM
lxgs4
lxgs4's Avatar
if i remember, to do the cam seals on the 98 gs400 the camshafts need to come out.
Old 03-12-08, 10:14 PM
pitmanr200
pitmanr200's Avatar
yes they do, but lexus only does that if they are leaking. Kind of if it aint broke dont fix it. So I wont buy that unless I need it. Just going to get the stuff im for sure I need.
Old 03-12-08, 10:50 PM
ranez0r
ranez0r's Avatar
why wouldn't you need to change the idlers??? ...... these 2 parts will set you back another $130
Old 03-12-08, 10:54 PM
pitmanr200
pitmanr200's Avatar
i dont know that is why I asked. tell me why you would have to change them!
Old 03-13-08, 05:13 AM
TRD911
TRD911's Avatar
I do not think that is the case. Please back up your comment?
Here is the manual for the VVTI 2UZ motor.. You can clearly remove the VVTi pulley..
I will look for the section that shows the seals..
BP
File Type: pdf
Old 03-13-08, 05:20 AM
19psi
19psi's Avatar
the idlers are a case by case basis. if they still roll smoothly with no friction and no noise i usually leave them alone. kind of up to your personal preference. the bearings can fail and then you're basically doing another t belt job to change the idlers.
es30000000
06-07-12 05:19 PM
LEX4LIFE
Maintenance
07-08-09 06:38 PM
RUDUN
Maintenance
02-05-09 07:50 PM
HD-GS4
06-01-05 12:01 AM
Quick Reply: 98 gs400 timing belt kit Part #'s
