So i've decided to order a set of rims from the land of the rising sun. They are Work Eurolines. The specs are 18X9 offset 29 fronts and 18X10 offset 30 rears. I'm thinking of keeping the stock suspension. Will the rears rub without a roll?
Thanks!
Reason: updated offset
You should be fine. I'm running pretty much the same fitments. 18X9 ~30 in the front with 235/40. I'm dropped over two inches with barely a finger gap, no fender mods, and don't rub.
