Door Lock Acutuators DIY ???
Old 06-07-09, 03:18 PM
  #331
burny
burny's Avatar
The master door lock switch inside the car locks and unlocks all 4 doors. The remote fob will not lock or unlock any of them. The battery is new in the FOB so I am just trying to figure out what is broken.
Old 06-08-09, 08:17 PM
  #332
DirtyE30
DirtyE30's Avatar
When I use the remote, only the passenger side locks or unlocks. Would the driver's door lock actuator being broken affect the remote locking/unlocking of the rear door?
Old 06-14-09, 08:21 PM
  #333
sanssome
sanssome's Avatar
This is a great guide and I used it to successfully replace my drivers door actuator. I did not remove the window, simply removing the bottom bolt for the window track (it's flexible) and moved it aside to remove the actuator.
Unfortunately I just failed on trying to replace the right rear door however and had to give up on first try. The problem lies in removing the right bolt on the door handle. If anyone knows of a way to remove that bolt or remove the actuator rods from the handle without pulling it out I would like to hear how you did it. Someone else here said with patience the rods will come off, but if you can add specifics, like where the retainer clips are located and which direction they flip, that would help. These rods seem clipped on a different way than the front door handle.
There's another good guide out there for a rear door actuator replacement where the guy fashioned his own 10mm wrench to do this. I managed to get my small 10mm wrench on the bolt and turn it just enough to crack the seal, but it hits the contour in the door side panel and can't be turned any more. I am thinking I may be able to cut down the wrench to like 1/2 or 3/4 size and that will provide enough clearance for turning it a click. So this job is definitely diy possible, but the door handle bolts are the stickiest part on both front and rear doors and be mindful of this if want to do the rear.
Old 06-14-09, 08:33 PM
  #334
sanssome
sanssome's Avatar
Unfortunately I just failed on trying to replace the right rear door however and had to give up on first try. The problem lies in removing the right bolt on the door handle. There's not enough room to get a wrench in to turn the bolt. If anyone knows of a way to remove that bolt or remove the actuator rods from the handle without pulling it out I would like to hear how you did it. Someone else here said with patience the rods will come off, but if you can add specifics, like where the retainer clips are located and which direction they flip, that would help. These rods seem clipped on a different way than the front door handle.
Old 06-23-09, 08:45 AM
  #335
stevetrave
stevetrave's Avatar
Default Same as Sienna
This is the same door motor in the '04 Sienna mini-vans. Thanks to all who contributed to the post this saved me almost $900 plus set a good example for my kids on how to fix things. But, I had to buy a bunch of these to get the one I needed. I won't post the link to the ebay account - this isn't a sales add. But I thought I'd return the favor by selling this at a good price. So, the FC 280PC 22125 unit is sold on ebay and works great in this spot.
Thanks for saving me a bunch of cash!!
Old 06-24-09, 02:04 PM
  #336
jackyban
jackyban's Avatar
" Originally Posted by othater View Post
The FC-280PT-20150 motor (from Ebay, activesurplus-Ron) cap will work and has the correct connector also. You just need to take the little bushing out of the old cap and put it in the new cap so the spindle part won't wiggle."
Does anyone have instruction on how I would go about doing this? I just ordered some FC-280PT-20150 motor from Activeplus and plans to replace my Driver side motor. Thank you much!
Old 06-25-09, 02:37 PM
  #337
LexusMBF
LexusMBF's Avatar
You just remove the cap from the old motor, take the bushing and put it in the new cap. Just be careful not to drop and lost it. It's so small.
Once you have the item you will figure it yourself. It's not hard to do.
Good luck!
Old 06-28-09, 12:25 PM
  #338
2jzism
2jzism's Avatar
Does anyone one where to get these motors other than eBay? There's couple of them there but the sellers are asking in the area of $20 for an item that just costs a few bucks.
Old 06-29-09, 10:45 AM
  #339
kao
kao's Avatar
As i already said, fc280pc22125 is the greatest choice and rather cheap, near 3-4 bucks
Old 06-29-09, 11:06 AM
  #340
2jzism
2jzism's Avatar
kao
That's the one, and the price that I'm looking for. Would you know where I can pick a couple of the fc280pc22125 at that price?
Old 07-03-09, 08:14 PM
  #341
Mark
Mark's Avatar
Cannot find the motor online. May I have the link?
fc280pc22125
Old 07-03-09, 10:08 PM
  #342
tag16c
tag16c's Avatar
Smile Check out eBay again $9.99 each
The FC 280PT-22125 motors are back on eBay for $9.99 each
Old 07-04-09, 05:15 PM
  #343
GSteg
GSteg's Avatar
Wow price has gone up a lot!
Old 07-05-09, 09:09 AM
  #344
English66
English66's Avatar
I kind of have the opposite problem. my remote open and close all doors but my keys will not open or lock the passenger door. What can that be????
Old 07-05-09, 09:50 PM
  #345
GSteg
GSteg's Avatar
^^ Has the lock ever been replaced on that door? Is it original?
Quick Reply: Door Lock Acutuators DIY ???
