what are these
Old 05-13-07, 10:02 AM
lexluger71
lexluger71's Avatar
Default what are these
i was cleaining my trunk , and i opened the flaps on the side, can someone tell me what are these hoes for going under the car..
Old 05-13-07, 10:04 AM
lexluger71
lexluger71's Avatar
here is the other side
Old 05-13-07, 10:11 AM
lexluger71
lexluger71's Avatar
here is where it leads to under the car by the wheel. i was going to pull it out , but i need to know what it does first.
Old 05-13-07, 10:15 AM
jayyyy
jayyyy's Avatar
i wouldnt recommend you pulling it out.i think its helps drain water out of the rear somehow
Old 05-13-07, 10:16 AM
golfkid777
golfkid777's Avatar
Those are the sun roof drains. Pull them out and you will not be a very happy camper unless your car is never washed or never sees a glimpse of water.
Old 05-13-07, 10:18 AM
macd7919
macd7919's Avatar
I'm pretty sure that is the drain from the roof etc... for if/when water gets in. It's going to leave an open hole in the car for dirt/water/road grime to come in through. Secondly, it's a factory drain of some sort and obviously there for a reason, not just to look pretty. It would probably be a really bad idea to take that out. Why did you want it out if you dont mind me asking?
Old 05-13-07, 10:30 AM
LEXUS_KID
LEXUS_KID's Avatar
Don't take them out
Old 05-13-07, 11:04 AM
Joelseff
Joelseff's Avatar
go ahead take it out and see what happens....you know what they say about curiosity
Old 05-13-07, 11:18 AM
blacksc400
Car Chat Moderator
blacksc400's Avatar
Looks nasty... I don't wanna look at mine..
Old 05-13-07, 03:22 PM
dusouth
dusouth's Avatar
looks like there could be a slow leak by look at the pic is your trunk getting water in there?
Old 05-13-07, 03:24 PM
benzo555
benzo555's Avatar
sunroof drain...
Old 05-13-07, 09:18 PM
lexluger71
lexluger71's Avatar
some power steerin fluid spilled in there so i was going to clean it out, just wanted to know how important those hoes was. i got alot of dirt to clean out of there. now that yall mentioned it , it does make sense. i bet yall keep yall trunk slots clean like mines. lol
Old 05-13-07, 10:04 PM
macd7919
macd7919's Avatar
I thought you meant take them out permanently. I wouldn't take them out at all but if you just want to clean take some simple green from home depot and spray it in there then wipe it up. It's non-toxic and will help with the oil residue
Old 05-14-07, 05:00 AM
JeffTsai
JeffTsai's Avatar
Those are the sunroof drains. It's for when you accidentally leave the sunroof open thru a storm or whatever. It will help prevent water from going into the car. This only applies for the tilted open, and not if the roof is fully open(there's no magic net to catch water if the roof is open all the way). If the sunroof is closed, everything should be sealed and those drains are not gonna be doing anything. So, if you can trust yourself never to leave the sunroof tilted open then it should be ok to remove those
Old 05-14-07, 08:12 AM
BLiu
BLiu's Avatar
Heh Heh....He said Hoes...Heh....KEWL.
Quick Reply: what are these
