99 GS300 Intermittent Hesitation Problem
I have had 3 Toyota mechanics work on this problem and no one can find the problem.
Problem:
Intermittent hesitation (engine misfire or transmission slip?) with normal acceleration, usually between 30 and 50 mph.
Problem does not occur with very light acceleration.
Problem does not occur if I keep transmission in 4th gear instead of drive.
Problem seems to occur more in the afternoon rather than the morning and more often with the AC running (warmer temperatures).
Problem never occurs when engine is cold.
Problem frequency has increased over the past 3 months ago.
95% of the time, the engine, transmission has excellent performance - smooth idle, acceleration, shifting, etc
Mileage:114,000
Replaced plug wires and air filter recently - problem still exists
Changed the spark plugs and cleaned the injectors approx. 10,000 miles ago.
Serviced the transmission, replaced timing belt approx. 18,000 miles ago.
Reset ECU 3 days ago - no change
Any suggestions will be greatly appreciated
Problem:
Mileage:114,000
Thanks for the suggestion. I'll clean it and see what happens. Where is the MAF sensor located and how do I clean it. I did not see any posts for this for a 99 GS300
small sensor with wires coming out of it right after the filter location approximately 2-3 inches from airbox. Did you check for cracks while the engine was running? thats how i found one leak on my other car, I moved the ducting around and the engine started changing rpm...
removed the MAF sensor, looked clean but blew out anyway. Should I clean it with liquid, if so what would be best to use. I did check the plastic fittings for cracks again with the engine running, but no change in RPMs. Thanks again for you help.
Blowing it out won't do anything. You need to clean off the built up dirt, oils, and gunk off of there. Dip a Q-Tip in rubbing alcohol and very gently clean the sensor wire. The MAF sensor is actually in the hole, and not the bulb looking temperature sensor on the tip. Be careful not to put big pressure on the sensor wires, just dab it and rotate the qtip slowly.
01, 2001, 99, acceleration, air, flow, gs300, gs430, hesitation, injector, intermittent, mass, problem, problems, sensor, transmission
