loose spoiler
e
thanks.. it's a factory spoiler, not a dealer item...
how do i access this metal bracket and rivits? does it require removal of the spoiler first?
To access the bracets first open the trunk and look under the sides of the spoiler that slump over the sides of the quarter panels. There will be a cover that is color matched that you can pop off. Once you carefully remove the covers you will see Phillips head screws that also except a long Flat head screw driver (2 on each side).
If the center of your spoiler is what 'seems' loose then don't bother. I had a spoiler on my GS and it seems that all of the factory spoilers do that due to them being hallow in the center. I did notice a little play on my spoiler and attempted to tighten the bolts and they wouldn't move on inch, so I just took it off haha.
Good luck!
Good luck!
lexusben
01-07-14 01:21 PM
