Broke your ABS/VSC sensor? Here's how to fix it!
Old 08-22-10, 11:36 AM
  #46
Big Mack
Big Mack's Avatar
Lightbulb
I would contact a local stereo shop that deals with the higher end gear. They will most likely have someone who can solder very well, as they should. They can probably help you out for a few shillings, and won't take nearly the time.
Just a suggestion.
Big Mack
Old 04-18-11, 08:36 PM
  #47
GS4_Fiend
GS4_Fiend's Avatar
Jeff, you wanna reload the pics? Thanks
Old 11-14-11, 09:38 AM
  #48
stevenjai
stevenjai's Avatar
Does anyone have the picture? I can't seem to see it.
Old 12-01-11, 03:41 PM
  #49
bigjussin
bigjussin's Avatar
It's not loading for me either...what if the codes exist for the sensors being bad, but they ohm out at 1.7?
I am Jack's confusion
Old 01-04-12, 02:32 PM
  #50
zzaldyy
zzaldyy's Avatar
can someone please re host the pictures?
Old 01-04-12, 03:51 PM
  #51
JeffTsai
JeffTsai's Avatar
Sorry the original pix are gone. Had a server crash back like 2 years ago lol.
My GS400 needs to have one of the ABS sensors repaired. I'll make a new guide soon and update this posting.
Old 01-05-12, 01:28 PM
  #52
philliptie
philliptie's Avatar
That would be great!
Old 01-05-12, 01:53 PM
  #53
neojungle1
neojungle1's Avatar
yea i would be nice..to post picture but i just trouble shooting by just reading your tutorial its while writing by the way i didnt get lost once reading it and i was able to determine all it was that the sensors where dirty from removing them to do the coil over I just clean them out place them back and (remember to those that are installing coil over.remember to measure the cable slack so you wont put pressure on them when turning your wheels and snap the cable )then I drove around for weeks and then just last weekend the lights turn off..
Old 01-06-12, 12:05 PM
  #54
Teasy010
Teasy010's Avatar
Thanks for this helpful posting.
Old 01-11-12, 09:31 AM
  #55
PR FIEBRU
PR FIEBRU's Avatar
So once fixed the light won't shut off immediately?
Old 01-11-12, 09:39 AM
  #56
SPRTNYDSN
SPRTNYDSN's Avatar
Since the LBJ snapped...I know it messed up the cable. Can't wait til the pics to come back, I like visual aids. Plus, I don't wanna pay 250.00, LOL.
Old 01-11-12, 10:35 AM
  #57
AZGS4
AZGS4's Avatar
There is a way to shut the light off immediately after you fix the sensor. I do not remember exactly what the procedure is, but it entails brake pedal pumps and something else. You can probably find it by doing a search.
Actually I just found it. Try this it worked for me:
Go to the DLC1 connector under the hood (that's the connector with "DIAGNOSTIC" marked on top next to one of the Fuse/Relay box.
1- Connect (jump) the terminals marked "Tc" and "E1" (diagram is under cap)
2-Remove the SHORT PIN in the DIAGNOSIC connector
3-Turn ignition ON
4- Pump the BRAKE pedal 8 times within 5 seconds... this will clear the DTC code stored in the ECM
5-Remove the "Jump " wire used and reconnect the Shot Pin.
Old 01-14-12, 04:33 PM
  #58
neojungle1
neojungle1's Avatar
nope it stood on for like a month and half it just turn off on it own and it feel a lot better not the brakes it felt the same even with abs light on.just when it rain had to be careful not to lock the wheels .., but my throttle response has come back it more snappy too.
Old 11-18-12, 02:11 PM
  #59
SPRTNYDSN
SPRTNYDSN's Avatar
just hoping anybody has pictures.
Old 11-20-12, 09:59 PM
  #60
YxUxMADDDD
YxUxMADDDD's Avatar
Jeff!!! My front left has a malfunction code reflecting on the Lexus computer. Help me out! $190 just to replace the sensor is crazy lol
Quick Reply: Broke your ABS/VSC sensor? Here's how to fix it!
