18x8,18x9 or 18x9,18x10
Old 09-18-01, 05:06 PM
BadBtsz4u
BadBtsz4u's Avatar
Should I go(for volk av3)18x8,18x9 or 18x9,18x10.Is there a big difference in look.Any pros and cons....Thanks
Old 09-18-01, 07:06 PM
Received 2,127 Likes on 1,379 Posts
If you want the same size all around, 9 is as wide as you can go. If not, widest you can do is 9 front and 10 back. Wider rims allows/requires wider (more expen$ive) tires.
Wider rims fill out the wheel wells better, although this also depends on offset, but a 9 on the back is going to look a whole lot better than an 8.
The common stagger is 8.5 front and 9.5 back - guess you can't get that?
Old 09-18-01, 07:10 PM
biggie27
biggie27's Avatar
an 8.5 and a 10 would look perfect on the lexus
Old 09-18-01, 07:33 PM
RacingAristo
Guest
Posts: n/a
With wider tyres, you get more traction. Usually when people put different size of tyres front and rear, they want performance. The advantage for having the same size all around is that you can rotate the tyres every now and then.
Keep in mind that bigger tyres do cost a little more expansive.
Old 09-18-01, 07:59 PM
BadBtsz4u
BadBtsz4u's Avatar
Ok thanks in the wheels im getting they offer 8,9,10 instead of 8.5 9.5etc.So what do you thing is my best combination regardless of tire price...thanks so much
Old 09-18-01, 08:48 PM
GSman
GSman's Avatar
I heard a lot of folks go with the 8.5/9.5 staggered setup. Has anyone actually put 9's on the front and if so, what tire size fits without rubbing? Also, if you go 10's in the back do you need to go wider than the 275/35?
Old 09-18-01, 09:08 PM
BadBtsz4u
BadBtsz4u's Avatar
Question
According to racingaristo the widest you can go is18x9,18x10.I guess 18x8,18x9,will be basically bethesame as 8.5,9.5,and probably my best bet.What do you think...thanks
Old 09-18-01, 09:11 PM
mkilty
mkilty's Avatar
I am running OZ Opera's on my car.
Fronts: 8.5-18
Rears: 10-18.
Tires are SO2's Pole Positions.
Fronts: 245/40
Rears: 295/35
This setup works perfectly for me. Everything fits.
Michael
Old 09-18-01, 09:18 PM
BadBtsz4u
BadBtsz4u's Avatar
Thanks Michael so are you saying I could go 18x8,18x10.Or should I go 18x8,18x9,or 18x9,18x10,In your respected opinion.Man I thought wheel selection was tough,now its really getting tricky......Mike
Old 09-19-01, 06:27 PM
Sleepyboi
Sleepyboi's Avatar
would 19X8.5 in front and 19X10 in rear fit?
Boris
Old 09-19-01, 07:18 PM
BadBtsz4u
BadBtsz4u's Avatar
Yes it would be perfect,unfortuntely some companies dont come in half sizes.
Old 09-19-01, 07:50 PM
RacingAristo
Guest
Posts: n/a
If you don't go to track, 18x8.5 all around is suitable for daily normal driving.
However, if you do go to track, having a wider tyres at the rear DOES help.
18x8.5 f 18x9.5 or 18x10 r is a good combo.
Anything larger than 18" is not recommended. Mostly for the look.
Old 09-19-01, 07:58 PM
mkilty
mkilty's Avatar
I would go 8.5 front and 10 in the back. That way you can play with your tire sizes.
Michael
Old 09-20-01, 12:58 PM
kuruption213
kuruption213's Avatar
would 18x8 or 18x8.5 all the way around look that bad. I'm not trying to race I just want my car too look nice, and also I don't have alot of money to spend on tires. what do you guys think?
Old 09-20-01, 01:17 PM
Intellexual
Intellexual's Avatar
If you want one size tire to go all around, I'd say 8.5 should be your minimum width.
8.5's all around wouldn't look too bad
Quick Reply: 18x8,18x9 or 18x9,18x10
