how to remove rear parcel shelf?
Old 09-07-05, 10:06 AM
Benjamin T
Benjamin T's Avatar
Default how to remove rear parcel shelf?
hi folks... i tried (again) to do a search and i can't find anything (again).
a fellow boardmember here has offered to swap his rear parcel shelf w/brake light for mine sans brake light.
does anyone have instructions on how to re/re this shelf?
Old 09-07-05, 11:17 AM
QuikLex
QuikLex's Avatar
You have to remove the back seat first...the bottom seat can be lifted up by pulling upward. after you remove the bottom seat, you will see the screws for the back part of the seat. there are also screw behind the headrest, remove the head rest and ift up the flap. then you can get to the rear shelf...
Old 09-07-05, 11:29 AM
ntran18
ntran18's Avatar
It's been a while since I did this myself. You may also need to take off your C-pillar panels.
Old 09-07-05, 01:55 PM
Benjamin T
Benjamin T's Avatar
whoa... how long would this take? what about the seatbelts?
Old 09-07-05, 02:10 PM
jonathancl
jonathancl's Avatar
You can take the seat bottom out and pull the seat back forward without detaching the seat belts.
It'll take you an hour, give or take.
Old 09-07-05, 02:17 PM
Benjamin T
Benjamin T's Avatar
and the c-pillars?
Old 09-07-05, 05:15 PM
sfkid
sfkid's Avatar
I forget the which cl member it is. Here is a link to his DIY site. Has a couple of pics as well.
http://lexusmodz.netfirms.com/
Old 09-07-05, 07:28 PM
Benjamin T
Benjamin T's Avatar
it's saying it needs to be updated
Old 09-07-05, 08:02 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
It's a good writeup
http://lexusmodz.netfirms.com/GS_DIY/rear_deck/
Once you do this, you'll also want to search on how to disable the brake warning light.
http://lexusmodz.netfirms.com/GS_DIY...le_brake_warn/
I've replaced my deck with 3rd brake light with one without and now sometimes wish I hadn't... the sound is much better with the solid deck (sub underneath) BUT I now can't swap out the rear spoiler as easily for one without a brake light built in like the OEM
Old 09-08-05, 05:45 AM
Benjamin T
Benjamin T's Avatar
ugh... i'm still faced with the problem of how to get around the seatbelts... it seems everyone replaces the original deck and never has to deal with how to pull the seatbelts thru the openings
i wasn't aware of a brake warning light. when i got the car the rear wing was already deleted and the light wasn't on.... hm.
Old 09-08-05, 05:52 AM
LEXUS_KID
LEXUS_KID's Avatar
Can you just remove the seat belts with a torx socket ???
Old 09-08-05, 07:25 AM
Benjamin T
Benjamin T's Avatar
it's that simple? maybe i'm making things too complicated... i was wondering about the seatbelt retractor... how do i make that part go thru the opening in the deck? or is there some way to do it from the buckle side?
Old 09-08-05, 09:13 AM
ntran18
ntran18's Avatar
You can also get the seatbelt out of the guide. It's just a piece of plastic that snaps together.
Old 09-08-05, 09:16 AM
Benjamin T
Benjamin T's Avatar
i was staring at the guides when i got to work this morning... do they slide sideways out of the deck from the side edges?
Old 09-19-05, 08:38 AM
Benjamin T
Benjamin T's Avatar
bump... i had no success getting the seatbelts separated from the shelf
Quick Reply: how to remove rear parcel shelf?
