GS advice
GS advice
Ok, guys.. My car was just finished completed with the paint and putting it back together by the body shop... But it will not start. When I got into my accident, it was running, then it dioed.. It will crank but will not start. OEM parts like radiator, condensor, airbox,, etc, etc.. were used. It will crank... but will not start. Almost sounds as if it is out of gas, but it does have gas... Just in case you are wondering.. Any ideas on what i should look for??? As far as I now.. everything was done correctly.... I have yet to check fuses..... But I would appreciate any ideas or input. t was a front end collision, no airbags deployed, no frame damage, no engine damage other than the parts metioned and the powersteering pump and pulley and reservoir. H E L P Please.....
Rock
Rock
Forum Administrator
The mass airflow sensor may be on upside down Rock. I don't remember how it hooks onto the OEM, but at least on some aftermarket youi can connect it upside down and it exhibits the same symptoms.
