What should you get 1st?
if you plan on getting a BBK, then make sure the rims are high disk and will clear them.
if you are getting regular sized slotted or drilled rotors then it really don't matter
well i f read correctly you want 20's and BBK
if you get the BBK all the other stuff lines, pads, rotors will come with the kit
probably get rims fiirst because you wont be able to fit a BBK on stock rims
check the vendors forum
they have a Group Buy going on right now
welcome aboard
johnny
welcome aboard
johnny
Originally Posted by rominl
ummm, for me though, i lower the car first (that's if you haven't done so)
yes, bbk is good, but you need to make sure it clears the wheel.
The One
Originally Posted by R1derfull
Brake pads, rotors, calipers, and brake lines or rims?
With all that said, I agree with the others that lowering should come first since you get immediate benefits in ride, handling, and looks. If you do shocks and springs, you will again have to think forward to wheels to see what the drop you want on the rim size. If you do coilovers, than no forward thinking is needed since you can adjust the height with whatever wheels you have, now and later.
Lowering options
Hi guys. On the subject of lowering, what is most cost effective set-up? Sounds like coilovers is the best way to go for any change in wheel size. Should sway bars be done at the same time?
Welcome.
Looking back when I first got the car, the very first thing that needs to be done is the suspension!
GS when stock is so mushy. I'm not an all out performance guy as compared to other members, but this is what I should've done a looooooong time ago.
Couldn't really lower the car b/c I'm still on 16's.
here is the order i did my car.. HOPE this helps
1. stereo/TV's
2. suspension (coils)
3. body kit
4. wheels
5. BBK kit
6. hood and grill
7. interior
8. motor (incomplete for a while)
1. stereo/TV's
3. body kit
4. wheels
5. BBK kit
6. hood and grill
7. interior
