View Poll Results: How much air do you guys put in your OEM 17" wheels/tires?
Below 32 psi (please specify your reason)
0.67%
32 psi (what Lexus recommends)
49
32.67%
33 - 34 psi (please specify your reason)
26
17.33%
35 - 36 psi (please specify your reason)
43
28.67%
37 - 38 psi (please specify your reason)
6.00%
39 - 40 psi (please specify your reason)
15
10.00%
Over 40psi (please specify your reason)
4.67%
Voters: 150. You may not vote on this poll
All GS owners with OEM 17s please report in
Old 09-16-04, 09:19 AM
Cadd
Cadd's Avatar
Thumbs up All GS owners with OEM 17s please report in
How much air do you put in your tires? If I remembered correctly, the door jam recommended 32psi (correct me if I'm wrong). But the wheels look kind of low on air at 32psi. So I raised it to 35psi.
Old 09-16-04, 09:51 AM
400DGRZ
400DGRZ's Avatar
My tires say no more than 44psi.
I run at 40.
Old 09-16-04, 11:49 AM
Alexus-Kia
Alexus-Kia's Avatar
my tires also say no more than 44psi.
i usually do about 39-40psi
Old 09-16-04, 11:54 AM
MGS4
MGS4's Avatar
40psi.
Reason: reduce inner tire wear (front tires)
Old 09-16-04, 12:25 PM
Cadd
Cadd's Avatar
These are the OEM 17" 235/45-17 tires that we're talking about right?
Seems like many of you are running psi that is much higher than what Lexus recommends. I wonder why Lexus recommended such low pressure? I understand they want to keep the ride as comfy as possible, but I'm sure the owners who opted for these optional 17" wheels know that they will lose some of the comfy ride.
Old 09-16-04, 12:33 PM
NT2SHBBY
NT2SHBBY's Avatar
guys he said 17's....the two that replied, if you read their sigs they run 19 & 20's.
I can understand 19's and 20's goin at 40psi, you need to.
I run my L-tuned 17's at between 32-34
Old 09-16-04, 12:51 PM
Dislexic
Dislexic's Avatar
Yup. 40 psi is for bigger rims. I ran my OEM 17's at 33 psi.
Old 09-16-04, 01:35 PM
corkycal
corkycal's Avatar
i run 39-40 because of camber wear at 33 (factory specs). my thinking is with higher pressure, the tire contacting the road will be more on the center.
Old 09-16-04, 02:13 PM
400DGRZ
400DGRZ's Avatar
No, I meant my 17's. I recently put them back on. This was yesterday at 40psi.
https://www.clublexus.com/gallery/sh...sort=1&cat=500
Old 09-16-04, 06:36 PM
Alexus-Kia
Alexus-Kia's Avatar
that is what i run on my 17's......
Old 09-16-04, 06:56 PM
ligflava
ligflava's Avatar
38, cuz i'm just hoping that it'll help a tiny bit for gas mileage.
Old 09-17-04, 05:31 AM
BLW
BLW's Avatar
38-I am running over sized tires 245/45. I like the bigger size for ride and looks. 0.3" taller and wider.
Old 09-17-04, 10:28 AM
EmeraldLexuSC3
EmeraldLexuSC3's Avatar
Post
I have OEM 17's and running 38-40psi (max44)
Old 09-17-04, 03:06 PM
Taran
Taran's Avatar
Default ...
Running 245/25/17 on stock 5spoke 17", Goodyear Eagle F1 GS-D3, max is 51 (i think) i keep it around 38-40. And they still always look kinda low..
Old 09-17-04, 05:42 PM
jefe
jefe's Avatar
stock 17s with bridgestone s03s here. i run 34 or 35 psi. i used to run 37-38, but i was getting more wear along the center of the tire in the rear. fronts wore fine at both pressures.
Quick Reply: All GS owners with OEM 17s please report in
