Benefits of Cold weather!
Old 11-07-03, 11:41 AM
mooretorque
mooretorque's Avatar
Talking
Cooler air = nature's intercooler. More oxygen (not air, we don't burn nitrogen, carbon dioxide, or any of the trace gases) is part of the story. But internal combustion engine is a Carnot cycle; all other things being equal, the thermodynamic efficiency is related to the difference between intake temp and exhaust temp.
All things aren't equal, since gasoline's vapor pressure (well, every other liquid's vapor pressure, too) drops as the temp goes down. At some point gasoline vapor begins condensing and is unavailable for effective cylinder combustion. So, efficiency/power begins to drop. Mostly a theoretical problem except for our members up where the temps get down to single digits and below......................
Old 11-07-03, 06:21 PM
Mr Johnson
Mr Johnson's Avatar
Originally posted by GS4fun
I'm sure she would get a kick out of it.....or someone would get a kick in the mouth....one or the other is certain!
Nah....
I told my wife about this thread and started by just mentioning the title. First thought in her mind was the same as mine!
Wonderful woman!
Old 11-07-03, 07:15 PM
Received 2,126 Likes on 1,378 Posts
Originally posted by Mr Johnson
The main benefit of cold weather is when I ask my wife to get the newspaper without a coat in her T-shirt...
Provides a place to hang your coat too.
Old 11-07-03, 07:58 PM
Letsride
Letsride's Avatar
Nah....
Wonderful woman!
Definitely a keeper
Old 11-08-03, 12:12 PM
doug_999
doug_999's Avatar
Worst part about cold weather is that my engine ticking is back! Plus I have to put the snows on now. At least the seat heaters are good in the car. I have to admit, for a single level system, it works well.
Old 11-08-03, 03:09 PM
cyclemax
cyclemax's Avatar
Someone paid attention in Thermo II......
Old 11-08-03, 03:39 PM
Hypermagic
Hypermagic's Avatar
Default Simple Equation
Simple calculations:
Carnott Efficiency = 1 - (input Temperature/output Temperature)
Input temperature is the ambient temperature, while your exhaust temperature is constant.
Therefore, if input temperature drop, the ratio of (input Temperature/output Temperature) drops as well.
Finally, 1 subtracts smaller ratio = bigger number -------> increase efficiency
Old 11-08-03, 08:45 PM
jefe
jefe's Avatar
Default Re: Simple Equation
wouldnt you want to use combustion temps, since they are higher than exhaust temps? (1-Tc/Th) also, what would be good estimates of the high temp.? ~600 C?
Old 11-09-03, 04:18 PM
Hypermagic
Hypermagic's Avatar
Regardless of the temperature reference you are gonna be using (T combustion or T Exhaust), if you lower the T intake (T cold) then you will have increase in efficiency.
mehran888
03-15-13 08:49 PM
jcoukos
01-04-13 05:02 AM
ancdmd
08-15-10 08:18 PM
Ice350
Florida Lexus Club
37
01-10-10 02:06 AM
mjr24
10-11-06 06:33 PM
Quick Reply: Benefits of Cold weather!
