Gs300 trc, abs and trs off light shows after driven a few minutes
I NEED HELP AS SCANNER DID NOT SHOW ANY ISSUES.
MY GS300 WILL SHOWS TRC ABS TRAC OFF LIGHT AFTER DRIVING FOR SOME MINUTES. PLEASE ANY HELP ON THIS
my email - phemobay85@gmail.com
whatsapp- +2348066058712
i awiaits your responses
Probably going to need more info to help you solve this one but I did has a similar problem and it turned out to be the throttle body dashpot. It had a torn diaphragm so it was causing a vacuum leak and throwing the TRC, ABS, light. Unfortunately the only way to get the dashpot is to get an entire throttle body. Hope thats helps...Good luck
Yours has an ABS light? I just have the brake warning indicator which is a picture of like a brake disk with () around it like this (O). It will illuminate if the foot brake is on or if the brake fluid level is low but mine is a JZS147 with the nitrogen brake booster so the brake system is almost totally different.
kasper634
GS - 1st Gen (1993-1997)
02-11-06 09:30 PM
