Can't get air out of brake lines
Old 07-07-16, 11:16 AM
SvenKivi
SvenKivi's Avatar
Default Can't get air out of brake lines
I fixed brake heads all gaskets and put new brake pistons all four wheels,and all brake system was try ,now new brake fluid and inside and i not get out air i pumbikng pedal every wheel ten times and abs dispenser have to nippel and exhorted this to but some air still inside !!
Old 07-07-16, 06:39 PM
TheMole
TheMole's Avatar
Have you tried first bleeding the caliper furthest away from the master cylinder?
Old 07-08-16, 01:44 PM
Mandrake
Mandrake's Avatar
Did you run the lines dry? If so, you might have to bench bleed the master cylinder, gravity bleed the lines and then bleed the lines.
Old 10-08-16, 10:10 AM
SvenKivi
SvenKivi's Avatar
now back brakes are good abs is working and now first brakes is not working good like still air inside ,only first brakes,
Old 10-10-16, 01:53 PM
skytechja
skytechja's Avatar
as suggested earlier.. bleed em from master cylinder n then the furthest wheel from the cylinder....
bleeding the master cylinder involves taking it off car , putting fluid in n haveing each connector properly bled,,,, doing this can also show u if ur mastr cyclinder is in good order.
example... LHD car... master cylinder will be left front...
bleed wheels in the following order:
rear right..then
rear left.....then
front right.....then
front left...
if its you alone, gravity bleed lines....
if done properly, you should be good... if not,, your brake booster could be going.
TolasLV
10-30-17 09:20 PM
speedkar9
08-19-17 07:52 AM
MattStarr
Suspension and Brakes
03-03-12 04:34 PM
toy4life86
14
09-03-10 05:14 PM
Avarec
SC- 1st Gen (1992-2000)
04-14-10 02:27 AM
Quick Reply: Can't get air out of brake lines
