KEEP IT REAL!!-Post your mileage
Old 04-21-03, 09:19 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
Default KEEP IT REAL!!-Post your mileage
I will start-
96 GS300-no Nak, no butt warmers, no TRAC
91,000 sum odd miles and usual GS issues-cupholder, door frame, moisture under trunk mat.
EDIT: My trunk struts were gone when the dealer sold me the car, but I thought the trunk was like a SC400s!!
Old 04-21-03, 09:33 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
1994 GS 300 (came with 24kt gold emblems, fully loaded)
I have between 100,000-101,000 miles
Driver side cracked trim, you guys know what I mean!! We all have that problem with the wind noise resulting from it!
The cup holder and the trunk struts are a lil worn making the trunk heavy.
Thats it!
Old 04-22-03, 02:14 AM
LB Lex
LB Lex's Avatar
93 GS, gold.
178,000 miles
Old 04-22-03, 06:14 AM
Sovero1
Sovero1's Avatar
93 GS blue, fully loaded (has everything but auto dimming mirror, did they have them back then?)
159K and change miles
moisture in spare wheel well
Old 04-22-03, 09:09 AM
Pianoman72
Pianoman72's Avatar
Guys I think there is a drain plug near the power antenna that might be clogged causing that moisture prob. I read that somewhere but haven't checked it out becuse I think mine is still dry.
'93, close to 52k miles, no nak, no trac, no "butt warmers," no cd, no sunroof.
same trim prob, trunk able to decapitate in one swoop, rear main seal leak, alleged P/S rack problem (probably BS - knock on wood). Could use new leather. Other than that, perfect!
Old 04-22-03, 10:32 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Default I have..
163,330 miles on my ride..
Old 04-22-03, 10:54 AM
Jmai22
Jmai22's Avatar
sounds like you finally broke your car in eh? lol
Old 04-22-03, 11:03 AM
D2-AUTOSPORT
Former Sponsor
Damn Piano,
52K on a 93????!!!!!
Thats only 5k per year, you must only back up, and go forward in your driveway!! Do you have any pics?
Old 04-22-03, 03:23 PM
alexamparo
alexamparo's Avatar
1995 smoke grey, fully loaded, no Nak, moisture in trunk, had broken cupholder but I fixed it better than if it was new, Wind noise from gap between trim and door panel (I will fix soon) and just hit 101K......I can use some new leather...its kinda hard and crusty in the front seats other than that its ok
Old 04-22-03, 06:52 PM
1quikGS
1quikGS's Avatar
1994 Light Gray ( Platinum) ---- Just turned 93k.....put on 14 k since I got it last October
Old 04-22-03, 08:22 PM
Seminole GS300
Seminole GS300's Avatar
1993 Gold w/ gold emblems. 120, 000 +. Trunk is screwed up, wind noise problem, brakes squeak, other than that no problems.
Old 04-22-03, 11:27 PM
supermodel
Registered User
supermodel's Avatar
1994 @ 88k
Old 04-23-03, 12:42 AM
indypwr
indypwr's Avatar
Thumbs up
1996 at 122,000 miles....................
Old 04-23-03, 10:20 PM
007's Avatar
1993 stock it came fully loaded, gold emblems, Nakamichi Sounds, Trac Control, Heated Seats, 12-Disc Changer etc. with over 214,000 but i changed the motor at 204,000. The engine i have now is out of a 94, when i bought it it had 44K and i now have 55K total on the engine.
Problems are rear power windows don't work, time for some new leather soon. We all may need to do a group buy on a leather trim kit as i talked about in an earlier thread. Maybe sometime this summer.
Old 04-24-03, 12:13 AM
indypwr
indypwr's Avatar
007, just curious, how much did you pay for yr motor and labor?
did your old engine gave up on you or you just wanted to change due to high mileage??
Quick Reply: KEEP IT REAL!!-Post your mileage
